Yorkie3621
Just had the main battery and 150amp fuse block replaced under warranty. Now, volt meter is going back and forth between 12.6 and 14.1, but I always remember it being solid 14.4v before.
Thinking I should put a charger on it but want to be sure before I do so I don't fry the ESS battery and mess anything up. Not used to charging a battery setup like this.
Best way to connect a charger?
Thank you.
Thank you.
