Altitude2020
Looks good, how did you extend the positive and negative wires on the Genpro?I went with the NOCO GEN PRO 10 amp 1 bank. I have the Genesis dual battery and space is limited under the hood. It looked like it would've fit on top of the fuse box, but I didn't want to run into any issues or hassel. Quite a bit of wiring:
The NOCO unit is mounted in the rear cubby and secured with two bolts through the plastic tub.
The AC port plug is mounted on the driver side, which helps remind me that I'm tethered before.
Cut and spliced wire through driver side of firewall, across to the center console tucked under all the way to the rear cubby.
