Deleted member 43521
Guest
So I am trying to make a custom decal for my JL 2.0. Researching specs for cold valve clearance…. I discovered an old engine that is uncanny similar to the “new “ GME engine.
If any one wants to dig more. The Suzuki J20 engine is spot on same specs as the JL 2.0 except for the compression ratio is .3 difference.
firing order is same for both: 1342
Displacement is same at 121.7ci
Cylinder block material: aluminum
Cylinder bore: 84mm
Piston stroke: 90mm
Both are DOHC and 16 valves.
The only difference is the turbo….
Cylinder bore: 84mm
Piston stroke: 90mm
