Oil Temperature 225-230 degrees F
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
Is oil temperature 226 degrees F pretty normal in city driving. As soon as I hit the freeway, it drops down to around 210 in a few minutes.
226 not too high I hope with in traffic but within the safe range where oil should be?
srt20
Wisconsin
JLUR Ocean Blue
Dont worry til 300*F, which you will likely never see.
BTW, I havent checked but I assume its got a thermostat in the oil cooling system like most other vehicles today.
Maverick909
Inland Empire
ive also seen mine run up to 230 when off-roading or while in traffic or long step accents. never seen it go past that though. i just keep an eye on the coolant temp more than the oil temp. as long as your within the jeep manual parameters it shouldn't matter
TJ2018
Eric
Orange County, CA
2018 Punk'n JLUR; 2020 Silverado Trail Boss
Given your locale I wouldn't consider that unusual at all. Stop and go (especially in traffic) limits cooling to some degree (pun intended ;)). No way a fan can match airflow and cooling you get at highway speeds.
Capricorn
Capricorn
Las Vegas, NV
Mine never go above 198
Then again, I use $100 motor oil..
That would be correct for 2.0L. I never saw it go more than 205* on my 2.0L (now my wife's).
But I guess the thermostat may have a different configuration for the Pentastar.
jeepdabest
Bobby
Arizona
2019 JL Sahara
Tribodyn TriDex 5w30
I’m testing to see if this oil is as magical as they claim, so far so good.
Tribodyn makes a 0-20w for the 3.6 V6 at only $85 a quart. Seems a tad expensive but I love the 2 year/30k mile life.
TheLodgeOne
Luke
Kansas City
2020 JLR
Mine gets to about 235° when off-roading or going up the slopes in CO. About the same time my check engine light and start/stop system failure light...
