wolf
30 psi give or take a psi, normal. Dual stage oil pump, above 3000 rpm willl be higher by design ie valve system. I have seen 75 or so on start up, when normal temp settles down to 30 or so psi. You can hit your passing gear and watch your oil pressure increase, then let off and it goes back to 30 psi. This is all by design. The off road pages with the gauge page is great on the 8.4.
