mgroeger
- Mike
- Feb 1, 2018
- Hurricane, UT
- 2021 JLUR 2.0T, 1991 YJ rock crawler
- Occupation
- I make microchips for a living.
- Vehicle Showcase
- 1
Yesterday, while putting on a winch, I removed the intake box to run the wires under it. While I had the box off I noticed a shiny spot about 2" inside the rubber intake connector boot.
I rubbed it with my finger and discovered it was dark thick oil, about a teaspoon or so worth that had puddled by the inner lip of the rubber boot.
I've owned many many cars and not once have I ever encountered this.
I am wondering the following:
Is there a problem with the PCV system?
Am I getting some sort of blow back from the valve cover hose? (I think there is one that connects the rubber duct to the valve cover)
Is it because the oil is so freaking viscous that it blows around?
It's real easy to check your own, simply loosen the clamp and pop the boot or take off the intake box cover and pull it out of the boot. If anyone would be so inclined I would greatly appreciate it.
One thing to note, I do like to get heavy on the gas. I will jump on it and run the engine up through the RPM range. Nothing abusive but let's say spirited.
