Do you mean your 392 is burning oil?Just curious how much oil people end up putting in their 392 engines for the first 500 - 1,000 miles?
Hey Miles, do you have the part number for that larger filter.I didn’t even check mine during break in. Just dumped it at 1100 miles and swapped to the larger SRT oil filter. Changing it again at 5K then every 5K after that.
Well that’s my problem. To me the dipstick could have been designed better, it’s hard for me to tell where the oil level is. The tiny crosshatch area on the end of the dipstick is hardly bigger than a thumbnail, and when you turn it around different ways you get different readings.How much to they usually burn. I changed mine at 1k and im at 3.7k right now and the oil life is around 57%. Ive check the dipstick and cant really tell where its at. It still looks very clean
No, but I’ve added about 1/4 of a quart at 700 miles. Maybe I didn’t need to? My biggest problem, like someone else mentioned, is reading the dipstick. The tiny crosshatch area at the end of the dipstick makes it hard to get an accurate reading. When I turn the dipstick different ways, I get different readings. Reason why I check it so much is because the manual tells you to.Do you mean your 392 is burning oil?
right now im at 57% oil life. From what ive understood is that the MDS of the 6.4L kills the oilWell that’s my problem. To me the dipstick could have been designed better, it’s hard for me to tell where the oil level is. The tiny crosshatch area on the end of the dipstick is hardly bigger than a thumbnail, and when you turn it around different ways you get different readings.
How does it do that? What evidence is that of that happening?right now im at 57% oil life. From what ive understood is that the MDS of the 6.4L kills the oil
