limeade
I'm coming up on doing my first oil change (others done free at dealer) and was researching oil filter selection. Back when I had an 04 TJ Rubicon, I used an oversized (longer) Mobil 1 or K&N Gold oil filter. I don't remember the filter numbers anymore, but someone had done the research and posted the alternate filters on the Rubicon Owners Forum.
Back then, one of the forum members had conducted an oil filter test and found the Mobil 1 and K&N Gold to be some of the better filters on the market. Coincidentally, their internal construction also looked to be identical, with the only difference being the nut on the base of the K&N Gold filter.
This got me to thinking if there were any oversized filters to use for the 2.0. The reason I like to run a longer filter is for the added oil capacity and extra filtration. I researched Summit Racing and oilfilterdata.com and located the below oil filters which appear to work.
http://oilfilterdata.com/index.php
An older article, but shows and lists the construction of different oil filters:
http://www.gmtruckcentral.com/articles/oilfilterstudy.html
The height of the oil filter is about 3.75" which these extended length filters are up to 4.87". To me, the big issue is if there's enough room to use a longer filter without it hanging too low and/or interfering with an engine skid plate. I will not be able to check this for another two weeks as I am out of the country for work. However, it is my intent to try either the Mobil 1-212, or Royal Purple 20-500 when I get home to see if it will work.
NOTE: The below oversize filters all have 22mmX1.5" thread, with filter bypass relief valve, anti-drain back valve, and most have a 17-21 psi burst rating (couldn't find that spec for some). I also did not bother to look up Fram filters.....it's my opinion they are some of the cheaper filters on the market and not worth the few dollars in savings. The K&N data was taken from Summit Racing, while the rest of the filter data is from oilfilterdata.com.
STOCK FILTERS
OVERSIZED FILTERS
If anyone has run a larger filter (or tried) please let me know if it worked or not. Or if you have found any additional filters which I didn't list.
STOCK FILTERS
Brand Model Thread ADBV BPV PSI Dia. in Ht. in Disp. in³
Royal Purple 10-48 M22x1.5 Yes Yes 3.15 3.62 28.21
Mobil 1 M1-113 M22x1.5 Yes Yes 3.15 3.62 28.21
K&N HP-1017 M22x1.5 Yes Yes 3.00 3.75 Unknown
Purolator L24484 M22x1.5 Yes 12-15 3.15 3.94 30.70
OVERSIZED FILTERS
Royal Purple 20-500 M22x1.5 Yes Yes 3.15 4.87 37.95
Mobil 1 M1-212 M22x1.5 Yes Yes 3.15 4.87 37.95
K&N HP-2011 M22x1.5 Yes Yes 3.00 4.78 Unknown
