Oil changes and oil filter housing
Kevinsjlruby
Portland, Or
2018 JlUR
7 months ago I traded my Jkur in for a jlur. Within 3 weeks, I was ready to change the oil. I called the dealer and spoke to 3 people all of who gave me 3 different oil weights, amounts, and oil filter. I guess the new JL is indeed different then the JK. It's a microscopic difference, but they said it is different. I have changed the oil on her 3 times now and last week my oil filter housing cracked and dumped my oil out. The part is not available anywhere for 3 weeks because it is different then the JK.
I am running into problems with 3 dealers here in the North West thinking the JK parts will work with the new JL. Has anyone else been having this problem? Does anyone have a dealer or service center they can recommend that knows the differences in the JK and JL? Is there an aftermarket oil filter housing available that is not plastic? Sorry for the shot gun of questions, I'm new
Multiple places..
@Kevinsjlruby
Kevin, Who told you that the JL part was not the same as the one for the JK? What are they saying the part # is ?
I was told by a local tech that the cap for the JK and JL are the same. I must have been mis-informed...?
By the way, when installing that part, torque to no more then 18 Ft/lbs. Be sure to install slowly and carefully tighten with your hand, first, to assure you do not cross thread it during install. Take care not to over tighten as the cap will crack.
2018 Wrangler 3.6L Pentastar engine
Chrysler/Jeep Oil filter part number is 68191349AA - (MO-349) / / 68191349AB - (MD-349) // 68191349AC (new number) but still MO-349
Mobil 1 Oil Filter: M1C-456A
Jeep recommends you use SAE 0W-20 Engine Oil, such as MOPAR, Pennzoil, and
Shell Helix. - 5 quarts oil
24mm socket for oil filter cover removal. Torque to 18 ft/lb.
13mm socket for drain plug (20 ft/lb torque)
Oil Life Reset:
1. Without pushing the brake pedal, push and release the
ENGINE START/STOP button and place the ignition to
the ON/RUN position (do not start the engine).
2. Navigate to Oil Life submenu in Vehicle Info in the
instrument cluster display.
3. Push and hold the OK button until the gauge resets to
100%.
Secondary Method For Oil Change Reset Procedure
2. Fully press the accelerator pedal, slowly, three times
within ten seconds.
3. Without pushing the brake pedal, push and release the
ENGINE START/STOP button once to return the ignition
to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Multiple places..
@AllMoparParts.com
Is the part number for the 3.6L in a 2018 JL oil filter cover different then the oil filler cap for the say 2014-2017 JK with the 3.6L ?
Can you have the OP out in getting this part?
@Kevinsjlruby .. Hopefully, you /we can get clarification on this from @AllMoparParts.com a sponsor here. They have been very helpful to forum members here in the past.
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
@AllMoparParts.com
The JL oil filter cap 68191350AA is shared with the JK as well as many other models and even engines as well.
hope this helps,
Benny
Multiple places..
That’s good to know! I may just get a spare.
I have one on the shelf in the garage. Got it in 2014. Never had the occasion to use it.
WXman
Central Kentucky
2018 Wrangler Unlimited
As mentioned, DO NOT OVERTIGHTEN. The new filter comes with a new O-ring. The O-ring should be swapped out each oil change, and the cap should be torqued to spec, not cranked down hard.
Between this, and the way they are over-filling the crankcases, I'm starting to really wonder if I should skip my last 3 free synthetic oil changes and just do it at home anyhow. Geez...
Bubba33
Saint Louis, MO
18 jeep wrangler Sahara JL
It should all be the same for the jeeps ,ram, Durango. Deffently sounds like you over tighten it. I ran 5w20 pennzoil in my 2013 3.6.
Multiple places..
@Bubba33
I have both JL and JK's in the household so all I keep and use around here is 5w20.
No reason to feel locked into using 0w20 with the JL.
Actually, more often then not, I find the 5w20 more readily available and less expensive then the 0w20.
Sure, I would not, not use 0w20 but seriously doubt I will ever use it, unless I save $ doing so.
Kajmcbride
Mammoth
2000 Jeep TJ, 2005 Dodge Ram, 2018 JLU Rubicon
I had a 2018 Dodge Caravan loaner when my JL was in the shop. The Caravan had a Penastar V6 and I noticed it used 5W20 oil. In addition it did not have ESS and could use E85.
Multiple places..
@Kajmcbride
Not sure what you post is trying to say but... ESS has little to do with why and whether a vehicle uses 0w20 or 5w20.
Google and read, regarding the difference between 0w20 and 5w20.
After this you yourself, will undoubtedly see, there is no reason why you cannot use 5w20 in your 3.6L JL or 0w20. Actually, after you read/research you may say, no way I will use 0w20 and from now on use only 5w20.
As for me, I use either or in my JL.... I use Pennzoil Platinum and will buy whichever (0w20 or 5w20) is available and less expensive..
In the JK, I only use the 5w20.
allieboy
Bob
Phoenix
2019 Sahara
@Kevinsjlruby
Oil Life Reset:
100%.
within ten seconds.
Does pan bolt require a washer
Multiple places..
@allieboy
No, the oil pan plug on the 3.6 L does not.
IF you install a Fumoto Oil Drain Valve, DO, use the blue washer that comes with the valve.
allieboy
Bob
Phoenix
2019 Sahara
@allieboy
Do you use Fumoto? Some complain that the oil cant drain completely. Thoughts?
Multiple places..
@allieboy
I have used them on Wrangler's for over 10 years. Never any issues with them.
Have also used them on heavy equipment, cars, trucks, aircraft and a Harley.
Using now on my JL and a JK.
I'm not concerned if say a slight tad of oil might not drain out ... a non-issue....
Read here if you are curious about the Fumoto Oil Drain Valve on a JL You will see caveats listed/mentioned in that thread.
https://www.jlwranglerforums.com/fo...m14-1-5-drain-valve-for-the-wrangler-jl.4441/
allieboy
Bob
Phoenix
2019 Sahara
@allieboy
Thanks for your quick reply
