Oil Catch Can and Blow-by
Jeepin' John
Raleigh, NC
2020 Gladiator Sport S
Wait, I keep 5W30 in the jeep in the summer, it even says 5W30 on the cap. 2.0T Etorque.
I *might* put a thinner grade in the winter, unless the warranty people are watching.
no kidding, I had no idea the 2.0 takes 5w-30. That's food for thought. Pentastar here, and trying to get rid of low speed pre ignition
Jeepin' John
Raleigh, NC
Any evidence that oil consumption is up on engines using 0w-20? In my experience, it’s never the oil’s fault. Poor PCV design is most oil consumption that is considered “normal”.
i don't care about oil consumption specifically. I'd be fine with using the same amount as long as it doesn't end up in the combustion chamber.
I want to eliminate low speed pre ignition in my pentastar, and -think- it's because too much oil is ending up mixing with fuel in the combustion chamber due to the oil being thinner
every tech article i read about LSPI seems to talk about oil the most and what oil companies are trying to do to reduce LSPI with oil formulations. Why would they be doing that? I think that's a hint that they know high-compression engines running 20-weight oil for fuel economy purposes are having more oil in the combustion chamber, causing knock.
But it's just an idea i wanted to float to the guys who know more about this stuff
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Are you having an oil consumption problem?
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Just keep in mind that nasty oil you drain from the catch cans is the exact same oil that is circulating in the rest of the engine.
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, JTuRD
Not really, the oil in the catch can has all the contaminates that have boiled out of the oil (water, unburned hydrocarbons, blow-by etc.)
Gregj
Rodeoflyer
Bert
Conifer, Colorado
Gregj
Yeah personally I'd rather have those contaminants in a catch can than reburned through my intake and exhaust system causing loss of catalytic converter life, carbon buildup, etc.
OutlawBeard
Kansas City, MO
2021 JLUR Gecko Ordered 5/4/21 Delivered 8/27/21
Is there any consensus on which catch can is "best"? I have a 2.0T Non-Etorque
Rodeoflyer
Bert
Conifer, Colorado
They all perform the same function. I knew I would be emptying mine often so that was something I took into consideration. The mishimoto has a drain line with petcock under the front driver side. Takes seconds to empty it.
OutlawBeard
Kansas City, MO
Im leaning towards the Mishimoto but I don't believe there's a drain line with the 2.0 kit, it reads towards the bottom of their site that they don't recommend the use of a drain kit with this catch can.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Gregj
The cans are only catching a small portion of the oil that is circulating under the valve covers, what about the rest of the oil, why would it be any cleaner than what the can catches?
Gregj
Greg
West Texas
I am neither for or against catch cans but I think you misunderstand their location, they are plumbed into the PVC hose and separate out the oil vapor in the crank vapors that are entering the manifold, ie the “blow-by”. They are not catching any of the oil circulating under the valve cover. The oil circulating under the valve cover goes through the filter.
Gregj
Rodeoflyer
Bert
Conifer, Colorado
Interesting.. it's not even in the same location as the 3.6l. There must be something blocking the driver side down to fenderwell.. hmmm.
mwilk012
Oklahoma
Service
Gregj
Same air/oil mist that is in the crankcase is under the valve covers. The pcv hose comes off the valve cover. The oily mist is literally sucked right out from under the valve cover.
Rodeoflyer
Bert
Conifer, Colorado
Exactly.. the same oily mist combined with fuel dilution and combustion gases. It's a nasty mix that used to vent to atmosphere, now it's reburned.
Gregj
Greg
West Texas
Right, I think he was under the impression that the catch can was somehow integrated into the valve cover instead of in the PVC hose.
