- Tim
- Jan 16, 2018
- Poulsbo, WA
- 4x4 of all kinds
- Occupation
- Part of the Northridge4x4 team
The JL capacity is 5 quarts for both the 3.6 and the 2.0T.
The JKs engine oil capacity is 6 quarts, which is why you'll hear some people say to use 6 quarts, they're just used to 6 qts. for the last 11 years.
3.6 needs API Certified SAE 0W-20 Engine Oil that meets FCA Material Standard MS-6395.
2.0T needs API Certified SAE 5W-30 Fully Synthetic Engine Oil that meets FCA Material Standard MS-13340.
Instead of changing the oil every 3,000 miles, think about changing the filter every 3,000 miles and the oil every 6,000 miles.
With today's standards, if you use a good quality oil, you should easily be able to go 6,000 miles or more, it is the filter that I would be more concerned about. Most automotive filters do not have a lot of filter paper in them and can easily be used up within 3,000 miles, depending on driving environment.
Doing a little oil sampling/testing during your oil change will tell you how dirty your oil really is. It is fairly inexpensive and you only need to do a couple samples until you find the "sweet spot" for change intervals.
Many of the larger auto parts chains have oil sampling kits available.
