Offroad+
AcesandEights
Aces
So. Oregon
2022 Jeep Rubicon 2D, with extra guacamole
What the hell is Offroad+ if you have a manual transmission?
RDoug
Doug
North Carolina
'22 JLURD; '19 E450 Wagon; '21 R1250RS
From the owner's manual, I'd assume it still gives you everything below save for the black lined sentence:
4L (4WD Low)
ļ¬ Engine/Transmission Calibration: Rock Crawl and controllability focus, change in shifting schedule when rock crawling, pedal calibration shifted to de-gain and low range, operates at lower vehicle speeds
ļ¬ Traction Control: Aggressive brake lock differential tuning at slower speed or FIRST gear
ļ¬ Off ROAD+: Recall the last status between ignition cycles
4H (4WD High)
ļ¬ Engine/Transmission Calibration: Improved sand performance/ wheel slip focus, change in shift schedule for sport mode, pedal calibration set to aggressive, operates at elevated vehicle speeds
ļ¬ Traction Control: High wheel speed, slip tuning brake lock differential with no engine management
ļ¬ Electronic Stability Control: ESC Off with unlimited speed
ļ¬ Off ROAD+: Will default to OFF between ignition cycles
DanW
Indiana
Itā€™s the button we will likely never push in our 6 speed :giggle:
Lol, it came out later, so my 2018 JLUR 6 speed doesn't have it. Never missed it, unless it shuts off TC in sand when at high throttle. If I don't do that it retards engine power and I can't go. Shut it off and I can throw rooster tails and rip it!
My wife's 2021 JLUR auto has it. I'm looking forward to messing with it to see what it does. But I'm betting it is not a game changer.
Has anyone actually used it and loved it? Tell us about what you feel it did for you?
DavidArmen
Los Angeles, CA
2021 JLUR
Really isnā€™t a game changer. The main thing I notice in 4H is it changes the acceleration pedal feel and the shift points get raised a bit. Iā€™ve never tried it in 4L.
At Risk Ute
Christian
milehightrails.com
ā€˜94 YJ, ā€˜21 JLR, ā€˜22 JLUR XR, ā€˜23 392 XR
Retired Navy
Exactly, not a game changer. Best way I can describe itā€¦ push the button if you want to go faster in 4H or slower in 4L.
Find myself using it more with 4H. Lots of braking and gear hanging in 4L.
Play around it with it. One more arrow in the quiver. Guess with a manual youā€™d have the braking and different throttle responses.
AcesandEights
Aces
So. Oregon
Shift points, in a manual?
JeepFiend
Michael
Bryan, TX
2022 Wrangler Rubicon 2 Door, 2011 Ford F-150 STX
System Administrator
supposedly, along with some other button pushes, it allows you to lock your rear locker in 4hi
