Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
Best all around car I've ever owned. A little off topic in the Jeep forum, but like that our Marina Bay Blue matches Ocean Blue pretty closely. This one goes back in July, probably get another... or the Plaid+ Model S is looking appealing. I had a P85+ a while back... Wife has an X7 M50i which is a beast.
I saw one on the street yesterday and was thinking, ”At least BMW hasn’t put buck teeth on the 5 series yet.“. Of course that will happen at some point but at least for now we can enjoy this as one of the more beautiful cars on the road.
As for the 392. I’m of the opinion that if I’m going to have a lot of power, I’m going to bloody well use it. I’ve got a Raptor and I put that engine through its paces regularly (both on and off road). But I’m just not sure I’d get that opportunity as much with the 392. Can the platform even handle that power when on road? We all know the Wrangler’s steering woes. IMO the steering needs a total overhaul with that much power. I simply have concerns with that particular Wrangler.
DaltonGang
Houston, Tx
So, for $75-$80k, do you think that FCA will put primer under all hinges, to stop the inherent corrosion problem?? It should only cost FCA a couple of dollars to do this.
0II392II0
Kevin
Washington
JLURH
Getting pretty
Watching the most recent video from Toledo Jeep Wrangler JL Production - Bing video it looks like the answer would be no. You are not able to see the tailgates being painted but all the door are on when it goes through the painting process and I bet that would disrupt the assembly line too much.
DaltonGang
Houston, Tx
Getting pretty
Not good news.
So, 75k-80k for a Wrangler that is going to start rotting in 2 months-2 years, at all hinges, just like the $30,000 Wranglers?? Wow!!!
demisx
Dee
Desert Hot Springs, CA
2021 JLU Rubicon 4-door (black)
Visit the Jeep site and compare the versions. The 392 is only 0.8” taller than the Rubicon. Then check out Motortrend article where it mentions the lift and the clearances.
This is odd. I’ve just installed the Mopar 2” lift on my 2021 JLUR and I gained on average ~3.5” over stock Rubicon. I’d expect 392 with the same Mopar lift to be pretty close to that.
m5guy
Lawton, MI
2019 BMW M5, 2020 GMC Denali 3500HD, 2019 Unlimited Rubicon, 2018 Mastercraft X26, 2020 BMW X7 M50i
This is odd. I’ve just installed Mopar 2” lift on my 2021 JLUR and I gained on average ~3.5” over stock Rubicon. I’d expect 392 with Mopar lift to be pretty close to that.
Really need to get our hands on one. I can't believe it's the same Mopar lift given the healthy weight increase with the 392. All I have is speculation at this point though.
BCMgunner
Eli
2020 G550 1.5” lift in 33” Ridge Grapplers
I beg to differ. Last time I had a V8 solid axle rig it was a 16’ G63 back in 16’. 560hp, 562 ft/lb and recirculating ball steering! Thing swayed, leaned, lurched and dived... it was a blast! An entertaining ride, even at legal speeds. Im hoping for all the same with the 392. Of note, the 392 has almost the same power to weight ratio (0.092 hp/lb) as the 16’ G63 with 563hp (0.094hp/lb) and 21’ G63 with 577 hp (0.099)
Chew on that for a bit.
Jeep tunes each suspension’s springs specifically for the Wranglers engine weight. I.E. the diesel specific Mopar lift springs provides the same lift as the 3.6L specific lift springs.
milesjj_20
Miles
San Diego
N/A
As someone that is very new to the Jeep brand, I have to ask out of sheer curiosity what is the fascination with the 392 that people are willing to dish out that kind of dough?
BCMgunner
Eli
stylett9
Southern California
FJ80, JLU Rubicon
Finance
Since it's coming stock with the 2inch MOPAR lift, I'm curious if they'll have a longer front track bar (non adjustable). Maybe a part people can buy for those that prefer factory parts.
pnut
pnut
Michigan
2021 Wrangler 392 35's, and 2015 JKU 35s (wife's)
  • Thread starter
  • Thread Starter
  • #134
Anybody notice the 392 has Fox “ hydraulic rebound stop(s)” up front like the Mojave?
https://s3.amazonaws.com/chryslerme...bicon_392_Specsla6s2mf70hctfgb5q521eniaq4.pdf
I'm not sure if that means the internals of the shocks or the Mojave bump stops. Here is the actual verbiage.
The Mojave has Fox hydraulic bump stops.
The 392 photos have shown normal bump stops. But it would a friggin HUGE thing if they came with the Fox ones on the Mojave. I was planning to put in King air bumps, but wouldn't need to if the 392 had these.
Go Outside
Eric
2020 JLU
For $80k you could buy a convertible Corvette that you can actually explore the potential of that HP. Another $30k gets you a Lamborghini.
Extreme Terrain
