Official: 2018 Jeep Wrangler JL Specs, Info, Wallpapers...
JAY
Administrator
Administrator
Jay
Wrangler
Admin
Here are the official specifications and wallpapers for the 2018 Jeep Wrangler JL.
ENGINE: 3.6-LITER PENTASTAR V-6
  • Available: Standard on all models
  • Type: 60-degree, V-type, liquid-cooled
  • Displacement (cu. in. / cc): 220 cu. in. (3,604 cu. cm)
  • Bore x Stroke: 3.78 x 3.27 (96 x 83)
  • Valve System: Chain-driven DOHC, 24 valves and hydraulic end-pivot roller rockers
  • Fuel Injection: Sequential, multiport, electronic, returnless
  • Construction: Aluminum deep-skirt block, aluminum alloy heads
  • Compression Ratio: 11.3:1
  • Power (SAE net) (hp / [email protected]): 285 hp (209 kW) at 6,400 rpm
  • Torque (SAE net) (lb.-ft. / N•m): 260 lb.-ft. (353 N•m) at 4,800 rpm
  • Max. Engine Speed (rpm): 6,600 rpm (electronically limited)
  • Fuel Requirement: Unleaded regular, 87 octane (R + M)/2
  • Fuel Tank Capacity (gallons): 18.5 (2-door), 21.5 (4-door)
  • Oil Capacity: 5.0 quarts (4.7 liters)
  • Coolant Capacity: 10 quarts (10.1 liters)
  • Emission Controls: Dual three-way catalytic converters, heated oxygen sensors and internal engine features
  • Max. Gross Trailer Weight: 2,000 lbs. (2-door), 3,500 lbs. (4-door)
  • EPA Fuel Economy mpg (city/hwy/combined): 18/23/20 (automatic); 17/23/19 (manual)
  • Assembly Plant: Saltillo South Engine Plant, Saltillo, Coahuila, Mexico
ENGINE: 2.0-LITER TURBO I-4
  • Availability: Optional — all models
  • Type: I-4 16-valve with direct injection, turbo charging, with throttled, cooled EGR
  • Displacement (cu. in. / cc): 121 cu. in. (1995 cu. cm)
  • Bore x Stroke: 3.31 x 3.54 (84 x 90)
  • Valve System: Chain-driven DOHC, 16 valves
  • Fuel Injection: Direct Injection
  • Construction: Aluminum block, aluminum alloy heads
  • Compression Ratio: 10:01
  • Power (SAE net) (hp / [email protected]): 270 hp (200 kW) at 5,250 rpm
  • Torque (SAE net) (lb.-ft. / N•m): 295 lb.-ft. (400 N•m) at 3,000 rpm
  • Max. Engine Speed (rpm): 5,800 rpm (electronically limited)
  • Fuel Requirement: Minimum unleaded regular, 87 octane (R + M)/2, 91 octane or higher recommended for optimum fuel economy and performance
  • Oil Capacity: 5 quarts (4.7 liters)
  • Coolant Capacity: 9.9 quarts (9.4 liters)
  • Emission Controls: GPEC4 engine-management system with close-coupled catalyst; and wide range O2 sensor
  • EPA Fuel Economy mpg (city/hwy/combined): TBD — automatic (2-door); TBD — automatic (4-door)
  • Assembly Plant: Termoli, Italy and Trenton South Engine Plant, Trenton, Mich.
ENGINE: 3.0 LITER ECODIESEL V-6
  • 260 horsepower, 442 lb-ft of torque
  • "More robust" 8-speed automatic transmission only
  • Available on 4-door only
TRANSMISSION: 850RE AUTOMATIC, EIGHT-SPEED OVERDRIVE
  • Availability: Standard — 2.0-liter I-4; Optional — 3.6-liter V-6
  • Description: Adaptive electronic control or Electronic Range Select (ERS) driver-interactive manual control and electronically modulated torque converter clutch
  • Gear Ratios:
    • 1st - 4.71
    • 2nd - 3.13
    • 3rd - 2.10
    • 4th - 1.67
    • 5th - 1.28
    • 6th - 1.00
    • 7th - 0.84
    • 8th - 0.67
    • Reverse - 3.53
TRANSMISSION: D478 MANUAL, SIX-SPEED WITH OVERDRIVE
  • Availability: Standard — 3.6-liter V-6
  • Description: Synchronized in all forward gears and Reverse, multi-rail shift system with top-mounted shift lever
  • 50% shorter throws
  • Gear Ratios:
    • 1st - 5.13
    • 2nd - 2.63
    • 3rd - 1.53
    • 4th - 1.00
    • 5th - 0.81
    • 6th - 0.72
    • Reverse - 4.49
    • Final Drive ratio - 3.45 standard, 3.73 optional (4.10 Rubicon)
TRANSFER CASE: NV241 COMMAND-TRAC
  • Available: Standard on Sport and Sahara
  • Type: Part-time
  • Operating Modes: 2WD High; 4WD High; Neutral; 4WD Low
  • Low Range Ratio: 2.72:1
TRANSFER CASE: NV241OR ROCK-TRAC
  • Available: Standard on Rubicon
  • Type: Part-time
  • Low Range Ratio: 4.0:1
TRANSFER CASE: MP3022 SELEC-TRAC
  • Available: Optional – Sahara
  • Type: Full-time
AXLES
  • Front: Dana 30, Dana 44 on Rubicon models
    • Differential Type: Open (Dana 30) or Tru-Lok electronic locking (Dana 44)
    • Axle Ratios: 3.45, 3.73, 4.10
  • Rear: Dana 35, Dana 44 on Rubicon models
    • Differential Type: Open (Sport and Sahara) with available Trac-Lok anti-spin, Tru-Lok electronic locking (Rubicon)
ELECTRICAL SYSTEM
  • Alternator (standard): 160 amp
  • Battery: 600 CCA, maintenance free
SUSPENSION
  • Front: Solid axle, link coil, leading arms, track bar, coil springs, stabilizer bar
    • Stabilizer bar: Electronic sway-bar disconnect system — standard, Rubicon
    • Shock type:
      • Sport: Gas charged twin tube shock absorbers with full displacement Multi-Tuned Valve (MTV) technology
      • Sahara: High pressure gas charged monotube shock absorbers with MTV technology
      • Rubicon: High pressure gas charged monotube shock absorbers with MTV technology and hydraulic rebound stop
  • Rear: Solid axle, link coil, trailing arms, track bar, coil springs, stabilizer bar
    • Shock type:
      • Sport: Gas charged twin tube shock absorbers with full displacement MTV technology
STEERING
  • Type: Electro-hydraulic Power
    • Overall Ratio: 17.4:1 – 2-door, 15.6:1 – 4-door
    • Turning Diameter (curb-to-curb) (ft./m): 34.5 2-door, 40.8 4-door
  • Steering Turns (lock-to-lock): 3.6 -2-door, 3.2 4-door
  • P/S pump: Electro-Hydraulic
BRAKES
  • Type: Power-assisted, anti-lock braking system
  • Front
    • Rotor size and type:
      • 12.9 x .94 (330 x 24) vented rotor – Sport
      • 12.9 x 1.1 (330 x 28) vented rotor – Sahara and Rubicon
    • Caliper size and type:
      • 1.88 (48) twin-piston floating caliper – Sport
      • 2 (51) twin-piston floating caliper – Sahara and Rubicon
  • Rear:
      • 12.9 x .47 (328 x 12) solid rotor – Sport
      • 13.4 x .55 (342 x 14) solid rotor – Sahara and Rubicon
      • 1.77 (45) single-piston floating caliper – Sport
      • 1.88 (48) single-piston floating caliper – Sahara and Rubicon
DIMENSIONS AND CAPACITIES
  • Wheelbase: 2-door 96.8 (2,460), 4-door 118.4 (3,008)
  • Overhang — Front: 29.2 (741.6)
  • Overhang — Rear: 40.8 (1,036.3)
  • Track — Front: 62.9 (1,598)
  • Track — Rear: 62.9 (1,598)
  • Overall Length (includes spare tire): 166.8 (4,237) – 2-door, 188.4 (4,785) – 4-door
  • Overall Width: 73.8 (1,875)
  • Overall Height: 73.6 (1,868.4)
  • Liftover Height: 29.7 (756.4)
  • Cargo Width at Swing-Gate Opening: 41.1 (1,052)
  • Cargo Height at Swing-Gate Opening: 36 (942.3)
  • Load Floor Height: 30 (762.1)
CLEARANCES
  • 245/75R17 (Standard on Sport)
    • Approach Angle (degrees): 41.4
    • Breakover Angle (degrees): 25 (2-door); 20.3 (4-door)
    • Departure Angle (degrees): 35.9 (2-door); 36.1 (4-door)
    • Ground Clearance (inches): 9.7
  • 255/70R18 (Standard on Sahara)
    • Approach Angle (degrees): 41.8
    • Breakover Angle (degrees): 21
    • Departure Angle (degrees): 36.1
    • Ground Clearance (inches): 10
  • LT28570R17 (Standard on Rubicon)
    • Approach Angle (degrees): 44 (2-door); 43.9 (4-door)
    • Breakover Angle (degrees): 27.8 (2-door); 22.6 (4-door)
    • Departure Angle (degrees): 37
    • Ground Clearance (inches): 10.8
CURB WEIGHT
  • 2.0-liter (2- and 4-door)
    • Wrangler Sport
      • Automatic Transmission (lbs./kg): 4,010 (1,819)
      • Manual Transmission (lbs./kg): N/A
    • Wrangler Sahara
      • Automatic Transmission (lbs./kg): 4,380 (1,987)
    • Wrangler Rubicon
      • Automatic Transmission (lbs./kg): 4,175 (1,894)
  • 3.6-liter (2- and 4-door)
    • Wrangler Sport
      • Automatic Transmission (lbs./kg): 3,955 (1,794) / 4,200 (1,905)
      • Manual Transmission (lbs./kg): 3,970 (1,801) / 4,215 (1,912)
    • Wrangler Sahara
      • Automatic Transmission (lbs./kg): 4,345 (1,971)
    • Wrangler Rubicon
      • Automatic Transmission (lbs./kg): 4,145 (1,880) / 4,455 (2,021)
ACCOMMODATIONS
  • Seating Capacity (front/rear): 2/2 – 2-door, 2/3 – 4-door
  • SAE Total Interior Passenger Volume, (cu. ft. / cu. m): 103.7 (2.94)
  • Front:
    • Headroom: 40.7 (1,036) hardtop / 42.6 (1,083) soft top
    • Legroom: 41.2 (1,038)
    • Shoulder Room: 55.7 (1,417)
    • Hip Room: 53.9 (1,370)
    • Seat Travel: 8.1 (206)
    • EPA Front Volume Index: 53.8 (1.52)
  • Rear:
    • Headroom: 40.2 (1,023) hardtop, 41.7 (1,059) soft top
    • Legroom: 35.7 (904.2) – 2-door, 38.3 (974) – 4-door
    • Knee Clearance: 61.6 (1,565.9)
    • Shoulder Room: 57.7 (1,458) – 2-door, 55.7 (1,417) – 4-door
    • Hip Room: 45 (1,143) – 2-door, 56.7 (1,440) – 4-door
    • EPA Rear Seat Volume Index (cu. ft. / cu. m): 49.9 (1.40)
    • Maximum Cargo Width at Liftgate Opening: 47.9 (1,218.7)
    • Minimum Cargo Width at Liftgate Opening: 41.1 (1,052)
    • Maximum Cargo Height at Liftgate Opening: 36.0 (942.3)
    • Minimum Cargo Height at Liftgate Opening: 35.7 (907.8)
    • Distance between Wheelhouse Interior Trim: 45.0 (1143)
    • SAE Cargo Volume:
    • Rear Seat Folded: 72.4 cu. ft. (2.05)
    • Rear Seat Upright: 31.7 cu. ft. (0.89)
    • Total Passenger plus Cargo Volume, (cu. ft. / cu. m): 150.4 cu. ft.
WHEELS
  • Standard (Sport)
    • Painted steel, Low Gloss Black painted
    • Size 17 x 7.5 in.
  • Sport S (Standard)
    • Fully painted cast-aluminum with High Gloss Tech Silver
    • Size 17 x 7.5 in.
  • Sport S (Optional)
    • Painted and polished cast-aluminum with Low Gloss Granite Crystal
    • Size 17 x 7.5 in.
  • Sahara (Standard)
    • Painted spokes with polished cast-aluminum
    • Size 18 x 7.5 in.
  • Sahara (Optional)
    • Painted High Gloss Technical Gray with polished cast-aluminum
    • Size 18 x 7.5 in.
  • Rubicon (Standard)
    • Painted pocket with Mid-Gloss paint and polished cast-aluminum
    • Size 17 x 7.5 in.
  • Rubicon (Optional)
    • Size 17 x 7.5 in.
TIRES
  • Sport (Standard)
    • Size and Type: P245/75R17, on/off-road, black sidewall
    • Mfr. and Model: Michelin LTX MS2, Bridgestone Dueler HT 685, Bridgestone Dueler AT RH-S, Goodyear Wrangler Adventure AT
    • Revs per Mile (km):
      • 665 (413) – Michelin LTX MS2
      • 661 (411) – Bridgestone Dueler HT 685 & AT RH-S
      • 668 (415) – Goodyear Wrangler Adventure AT
  • Sahara (Standard)
    • Size and Type: P255/70R18, on/off-road, OWL
    • Mfr. and Model: Bridgestone Dueler HT 685, Bridgestone Dueler AT RH-S, Goodyear Wrangler Adventure AT
    • Revs per Mile (km): 649 (403)
    • Size and Type: LT285/70R17C, on/off-road, black sidewall
    • Mfr. and Model: BF Goodrich KO2 All-Terrain
    • Revs per Mile (km): 645 (401)
    • Four–wheel anti-lock brakes: Standard
    • Electronic stability control: Standard
    • All-speed traction control: Standard
***Some specifications are preliminary and subject to change***
2018 JL RUBICON and JLU SAHARA
2018-jeep-wrangler-rubicon-01-1.jpg 2018-jeep-wrangler-rubicon-02-1.jpg 2018-jeep-wrangler-rubicon-03-1.jpg 2018-jeep-wrangler-rubicon-04-1.jpg 2018-jeep-wrangler-rubicon-05-1.jpg 2018-jeep-wrangler-rubicon-06-1.jpg 2018-jeep-wrangler-rubicon-07-1.jpg 2018-jeep-wrangler-rubicon-08-1.jpg 2018-jeep-wrangler-rubicon-09-1.jpg 2018-jeep-wrangler-rubicon-10-1.jpg 2018-jeep-wrangler-rubicon-11-1.jpg 2018-jeep-wrangler-rubicon-12-1.jpg 2018-jeep-wrangler-rubicon-13-1.jpg 2018-jeep-wrangler-rubicon-14-1.jpg 2018-jeep-wrangler-rubicon-15-1.jpg 2018-jeep-wrangler-rubicon-16-1.jpg 2018-jeep-wrangler-rubicon-17-1.jpg 2018-jeep-wrangler-rubicon-18-1.jpg 2018-jeep-wrangler-rubicon-19-1.jpg 2018-jeep-wrangler-rubicon-20-1.jpg 2018-jeep-wrangler-rubicon-21-1.jpg 2018-jeep-wrangler-rubicon-22-1.jpg 2018-jeep-wrangler-rubicon-23-1.jpg 2018-jeep-wrangler-rubicon-24-1.jpg 2018-jeep-wrangler-rubicon-25-1.jpg 2018-jeep-wrangler-rubicon-26-1.jpg 2018-jeep-wrangler-rubicon-27-1.jpg 2018-jeep-wrangler-rubicon-28-1.jpg 2018-jeep-wrangler-rubicon-29-1.jpg 2018-jeep-wrangler-rubicon-30-1.jpg 2018-jeep-wrangler-rubicon-31-1.jpg 2018-jeep-wrangler-rubicon-32-1.jpg 2018-jeep-wrangler-rubicon-33-1.jpg 2018-jeep-wrangler-rubicon-34-1.jpg 2018-jeep-wrangler-rubicon-35-1.jpg 2018-jeep-wrangler-rubicon-36-1.jpg 2018-jeep-wrangler-rubicon-37-1.jpg 2018-jeep-wrangler-rubicon-38-1.jpg 2018-jeep-wrangler-rubicon-39-1.jpg 2018-jeep-wrangler-rubicon-40-1.jpg 2018-jeep-wrangler-rubicon-41-1.jpg 2018-jeep-wrangler-rubicon-42-1.jpg 2018-jeep-wrangler-rubicon-43-1.jpg 2018-jeep-wrangler-rubicon-44-1.jpg 2018-jeep-wrangler-rubicon-45-1.jpg 2018-jeep-wrangler-rubicon-46-1.jpg 2018-jeep-wrangler-rubicon-47-1.jpg 2018-jeep-wrangler-rubicon-48-1.jpg 2018-jeep-wrangler-rubicon-49-1.jpg 2018-jeep-wrangler-rubicon-50-1.jpg 2018-jeep-wrangler-rubicon-51-1.jpg 2018-jeep-wrangler-rubicon-52-1.jpg 2018-jeep-wrangler-rubicon-53-1.jpg 2018-jeep-wrangler-rubicon-54-1.jpg 2018-jeep-wrangler-rubicon-55-1.jpg 2018-jeep-wrangler-rubicon-56-1.jpg 2018-jeep-wrangler-rubicon-57-1.jpg 2018-jeep-wrangler-rubicon-58-1.jpg 2018-jeep-wrangler-rubicon-59-1.jpg 2018-jeep-wrangler-rubicon-60-1.jpg 2018-jeep-wrangler-rubicon-61-1.jpg 2018-jeep-wrangler-rubicon-62-1.jpg 2018-jeep-wrangler-rubicon-63-1.jpg 2018-jeep-wrangler-rubicon-64-1.jpg 2018-jeep-wrangler-rubicon-65-1.jpg 2018-jeep-wrangler-rubicon-66-1.jpg 2018-jeep-wrangler-rubicon-67-1.jpg 2018-jeep-wrangler-rubicon-68-1.jpg 2018-jeep-wrangler-rubicon-69-1.jpg 2018-jeep-wrangler-rubicon-70-1.jpg 2018-jeep-wrangler-rubicon-71-1.jpg 2018-jeep-wrangler-rubicon-72-1.jpg jp018-021wrtbf64h9o767tuvr20agqdcgpqr-2.jpg jp018-023wrii5p5arg2nc281gl9f574r4p9h-2.jpg jp018-024wrcdifj82b0d20r429fcnosl4one-2.jpg jp018-025wrc24h9i78nrcen216tc9gpva646-2.jpg jp018-028writ8hv51qums8rq5hdkbganlc96-2.jpg jp018-030wrb05neqn0vnhgjccu9qbsguac44-2.jpg jp018-031wrhdie4ee4r5v5r2t39c1087ba61-3.jpg jp018-032wrst5ogk7llos94m7rkkj0t8jj9c-2.jpg jp018-033wrg0sh9bnpnd03pg0grpahgbgi13-2.jpg jp018-038wr8jcvqb88sf9rkit3v0djsbsrms-1.jpg jp018-039wr8rle0ebp1m1tilu48tejb0ldpk-1.jpg jp018-040wr9sevcvjfrnri8l5ku9nhedbud-1.jpg jp018-041wrkneu7mrdjn9nlledhge61aj4lt-1.jpg jp018-042wrpi6o7uc3usn919ku7h9epb6o3b-1.jpg jp018-044wrqqj86n8hoeeisltu5umadr1489-2.jpg jp018-045wrfcqhp8fdon5qtt1kscm88v91t0-2.jpg jp018-046wrvknsmt33uribconvi9411h0r0s-2.jpg jp018-047wr336kl9pideuqrlqg5sa3hviine-2.jpg jp018-048wrdtckt9t8to0hgu88u0abpvmd98-2.jpg jp018-051wr69pppfuadp5u5vvgipkotantt3-1.jpg jp018-054wrpd8im67mkjubeglg9oiakf9uft-1.jpg jp018-055wra1m7n22njmc6lkef1rbrvlda2k-1.jpg jp018-056wrrg7rgqho7t2iv538lucdm11gd9-1.jpg jp018-061wrf58dfi5of6j0ddfsd9cs8d3b95-1.jpg jp018-062wrbcof5nq0ne8473vi1lm4qkd56r-2.jpg jp018-064wr8tdr6pgs4it8s66509c6s10iaa-2.jpg jp018-065wrq8tnvtcktsg1s1n5dg09hvd0il-1.jpg jp018-066wruk0krdsj2qmkj4pgg8nlludi7h-1.jpg jp018-067wr5ffgnrum156sqfmf84tl533ohr-1.jpg jp018-068wr3o6rjg3uv1slin3sb36fe70gan-1.jpg jp018-070wrfts3vqpf76q8ls1hrp2nqiuqh4-1.jpg jp018-072wrrd5qh5kfbog064u4emnrp724sr-1.jpg jp018-074wr8e6694mqu1i5597abpsjn44j8m-1.jpg jp018-075wroa1oeb2mg2r8vn4031md25gaoh-1.jpg jp018-076wrk5utqu7uibnl3a0rg8qa1ti7im-1.jpg jp018-077wr8gddm28jd1q5hjlf9l8mqj45g2-1.jpg jp018-078wr1u43ibns97bf418t6m4l0hk1lp-1.jpg jp018-079wrd8usvii1r1p1ds63aot1cm1ms9-1.jpg jp018-080wr346mtqbf9nlkko2jkms3lasim1-1.jpg jp018-081wrc5j34st3f7mnucbruan4hgrplv-1.jpg jp018-082wrbtgfhktp98btdsvvs1v0avorpd-1.jpg jp018-083wrkv8at2d424kn2f0el42v2ecah-1.jpg jp018-084wr63a4brp44q1uboil41jng0p6sg-1.jpg jp018-085wrdubqv5kqcicn0i6nhd7o61iap2-1.jpg jp018-086wr1r6ctbei1e39r7cl26qti3sd46-1.jpg jp018-087wr9eo6tfmu2b5qa5lvfo2m0mgcnv-1.jpg jp018-088wrqk2ejnsq8t73saltlm681sa0an-1.jpg jp018-241wrn3oiueoimlu6tefjfduc13u2t6-1.jpg jp018-242wrrr7jlb2445f5g79eic2ubdl80f-1.jpg jp018-243wrjfrvv8bc177b67en251626vi4p-2.jpg jp018-246wrhu83snhl755pgmevma8m21f7gs-1.jpg jp018-247wre9ct2frfuuir4pphi3bfn1ujh4-1.jpg jp018-248wrsc2envvi3r6to5ohr95jtkgk4r-1.jpg jp018-249wrefpoec97061e5sga7ueclj4urt-1.jpg jp018-250wrnkmacr1korgsi61cj3kmnpl960-1.jpg 2018-jeep-wrangler.jpg 2018-jeep-wrangler-2.jpg 2018-jeep-wrangler-4.jpg 2018-jeep-wrangler-5.jpg 2018-jeep-wrangler-6.jpg 2018-jeep-wrangler-7.jpg 2018-jeep-wrangler-3.jpg
SadSandwich
Jon
Go kart
More torque from the 4 than the 6 woot!
Bearded_Dragon
FL
2018 Mojito! Rubicon
Nice diesel bump! Sweetttttt!
Edit: fuck me, I see Jay just added diesel is only on 4 door models, that's extremely disappointing.
The Great Grape Ape
Canadian Rockies
2015 JKU AspenX 5spd , 2015 JK Sport 6spd
MOTHER-Fluffer !!
It’s a Frickickin’ SelecTrac II transfer case, not SelecTrac !!
Billy
Bend, OR
1997 TJ, 2017 JKU
So who makes the D478 6 speed?
AZCrawl
AZ
2018 Granite Jeep JLUR
Can someone now calculate the optimal gear ratio for running 37's now that we have these numbers?
  • Gear Ratios:
    • 1st - 4.71
    • 2nd - 3.13
    • 3rd - 2.10
    • 4th - 1.67
    • 5th - 1.28
    • 6th - 1.00
    • 7th - 0.84
    • 8th - 0.67
    • Reverse - 3.53
guarnibl
Scottsdale
'21 JLUR 392 XR, '21 JTR, '21 JLR, '09 JK
So Sahara has a leather dashboard and all the rest do not?
DanW
Indiana
Ape, is the D478 manual transmission a Tremec?
Rubitrux
