In the JK the Hill Start Assist is a feature you can permanently turn off. I havent used mine in years. I'm assuming this is the same with the JL. It is a nice feature at times and on my JK it varies the amount of time held based on how hard you push in the brake. A light brake to just barely hold the stop usually resulted in a 1 second hold on my JK while a hard press of the brake would hold for several seconds before releasing.in the JL manual it says this Hill Start Assist can be disabled......does anybody know if that's a one-time thing or would it have to be done every time the engine is started?
In my old Subaru Impreza it was a one-time thing, but then there was permanently an annoying orange light on my dash indicating it was disabled. Hoping that's not the case for the JL
The cluchless start was an automatic thing on the JK's. You didn't need to hit a specific button to do this. I haven't seen anything like that in the images for the JL interior so I imagine its the same way. That being said, I don't know how it works with the push button start on the JL.This sounds like a Clutch-Start-Cancel type situation.....am I right about that? I've got a Tacoma MT that's got a CSC button, and it works exactly as you guys have described. I push the CSC button, clutch is up and truck's in gear, and by just turning the key she starts up and immediately begins to move. Really helpful if you're afraid of rolling back with the MT. Rather than having a CSC button, the Jeep just goes into CSC mode when in 4L? Epic
If you guys are saying what I think you're saying, I'd want to permanently disable Hill Start Assist on a JL and just use this CSC feature when I need it, no HSA required. That'd be great
Good call, it’ll be interesting to see if the push button start makes a differenceThe cluchless start was an automatic thing on the JK's. You didn't need to hit a specific button to do this. I haven't seen anything like that in the images for the JL interior so I imagine its the same way. That being said, I don't know how it works with the push button start on the JL.
keep us posted!I think the hill start assist may eliminate the need for the clutchless start. I'll see if the clutchless start is there as soon as I can get on a dirt or grave road. I'm trying to remember, but I think I may have tried it and found it not to be there.
It’s under safety in the settings.Anyone know how to turn it off? Can’t seem to locate it in the uconnect anywhere.
The issue for some of us is that they took away a capability with this new keyless start button crap. We used to be able to move the vehicle for a short distance on just the battery and starter if the vehicle would not start and now it is not possible.I am wondering if there is a way to do a clutch-start-cancel on the new JL? My xterra had it and was useful a couple of times. I tried in the JL with it in 4L, engine off, foot on brake, clutch up, and hit the start button, and it just cycles through the off-acc-run options on the ignition switch.
In a way, you could get about the same results as the clutch-start-cancel by using the hill start assist, and when in a situation you would need this effect, you could make sure the hill start assist is on, and push in the clutch, start the jeep, then slowly let out clutch to get going but do it fast enough before the HSA disengages, so kind of what you were saying.
Wondering if anyone has figured out if there is a clutch-start-cancel option on the new JL?
