Off road questions
KeroRocks
Sonia
Massachusetts
Jeep Wrangler Rubicon 2021
Jeep Wrangler JL Off road questions Rubicon
I have a 2021 Wrangler Rubicon. I read the manual but still am a bit lost as to the options in the picture. I know about 4-lo
What is the red switch? Is that to disconnect the sway bar? and if it is then what is the sway bar/off road button.
Also when people flex their jeep (park one wheel up on a lift) what set up do they use? Do you disconnect the sway bar for that?
I've had a jeep for years but this one has a lot of bells and whistles that my old manual crank windows jeep didn't have.
Jazzicon
Jasmine
Concord, North Carolina
2021 Rubicon Extreme Recon, 2021 Toyota
Red buttons are for engaging your lockers….either rear only or both front and rear. The furthest button on the left is to disengage them. The sway bar button is for disconnecting and reconnecting your sway bar.
Disconnecting the swaybar will get you more flex..
Engaging both lockers is awesome for crawling over ALL the things…..but with the front engaged turning the wheels will be more difficult.
Rustynail11
Mansfield, TX
2022 Wrangler JLU Rubicon
Definitely reread the manual, it explains a lot. Also search for YouTube video, I am sure there are videos out there doing a walkthrough. If getting ready to go off-road study up, middle of the trail is no where to educate yourself on the features you have in your rig
Remorseless
NC
'22 JLR 2.0T, '21 KL TH 3.2, '19 Charger R/T 5.7
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast
The offroad + button will change vehicle tuning. In 4H, it will set the engine/throttle/traction control up for higher speed/sand/dune running. In 4L, off road + optimizes all those things for low-speed crawling.
Mikester86
Michigan wishing I was on a trail...
2022 JLR
Pretty much what I stated. Somehow it amused you. 🤷🏼‍♂️
Remorseless
NC
Off-Road Plus button if used in 4 high range will automatically adjust options for traversing sand. If used in 4 low range, it will automatically adjust options for rock crawling.
lmao, of course as soon as I post your post shows up, was excited there was a button someone hadn't mentioned lol
John VonJeep
Middle of Nowhere
Many
Keep in mind that OR+ does two completely different things depending on whether you're in 4Hi or 4Lo.
In 4Hi, OR+ is basically a Sand Mode button. Makes the throttle more sensitive and holds gears longer.
In 4Lo, OR+ does the opposite by dramatically softening throttle response for rock crawling.
I actually don't like OR+ in 4Lo, even when crawling. It makes the throttle feel very unintuitive. OR+ is very impressive in the sand. Very. I use it a lot.
Mikester86
2022 JLR
Let's see what the manual states about Off-Road +
When activated, Off Road+ is designed to improve
the user experience when using specific Off Road
driving modes. To activate Off Road+, push the
OFF ROAD+ switch in the switch bank. The
vehicle’s performance will improve depending on
which Four-Wheel Drive (4WD) mode is activated.
NOTE:
Off Road+ will not function in 2H mode. If the
button is pushed while in 2H mode, the cluster
display will show the message “Off Road+
Unavailable Shift to 4WD”.
When Off Road+ is active, the following features
will activate:
The Off Road+ telltale will illuminate in the
instrument cluster display
A mode-specific message will display the instrument
cluster display
Off-Road Pages will launch on the radio
head-unit if selected in radio settings
The Off-Road Camera will launch if selected in
radio settings
Once in Off Road+, the vehicle will begin to behave
in different ways depending on the 4WD mode in
use. The following enhancements will occur when
using Off Road+.
4L
Engine/Transmission Calibration: Rock Crawl
and controllability focus, change in shifting
schedule when rock crawling, pedal calibration
shifted to de-gain and low range, operates at
lower vehicle speeds
Traction Control: Aggressive brake lock differential
tuning at slower speed or FIRST gear
Off Road+: Recall the last status between ignition
cycles
4H
Engine/Transmission Calibration: Improved
sand performance/wheel slip focus, change in
shift schedule for sport mode, pedal calibration
set to aggressive, operates at elevated vehicle
speeds
Traction Control: High wheel speed, slip tuning
brake lock differential with no engine management
Electronic Stability Control: ESC Off with unlimited
speed
Off Road+: Will default to OFF between ignition
cycles
Cruise Control and Adaptive Cruise Control (ACC)
will not function while using Off Road+. A dedicated
cluster message will display indicating this if either
feature is activated while in Off Road+.
If the ESC OFF button is pushed while in Off Road+,
the following will occur on the vehicle:
Push of the ESC OFF Button: Traction Control
will turn off, but Stability Control will remain
active.
Hold the ESC OFF Button for five seconds: Traction
Control and Stability Control will turn off
Remorseless
NC
John VonJeep
Middle of Nowhere
Many
NOTE:
will activate:
cluster display
radio settings
using Off Road+.
4L
cycles
4H
speeds
speed
cycles
active.
I believe that
my summary
is better and more
intuitive than what the
manual provides.
KeroRocks
KeroRocks
Sonia
Massachusetts
So what if I'm plowed in with snow (I've had that happen) my old jeep got stuck (stock with no extras at all. Didn't even have power anything) I tried 4H and 4L and couldn't get out.
I'm assuming that will not happen with this one but what set up would work best for snow?
And what actually do the lockers do?
And I hope my questions don't seem too stupid.
