OEM auto dimming rear view mirror
FinnCustomKnives
Woodstock, GA
2021 Wrangler Rubicon Ecodiesel
Milledgeville Ga
2019 Jeep Wrangler Sport
Right under the dash on the passenger side. If you pull the top dash trim (Easy to do. only 1 bolt behind the radio bezel, and pressure clips) u can see it in a cut out I was able to stick my fingers in the cut out and unplug the connect which had enough slack to tap and solder my jumpers to the added pins
So your saying that the top of the dash has to come off to run the wires?
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
So when upgrading to the oem auto dimming mirror, is the 8.4" unit required? Or can it be made to function with the 7"?
Debating just going this route because I think it is an ideal setup for soft top jeeps. The C8 corvette's rear view camera has shown how much better a camera based rearview really is.
https://brandmotion.com/product/ful...r-for-jeep-wrangler-jl-2018-2020-fvmr-8876v2/
No it is not. The camera based rearview obviously brings into play additional benefits however you should ensure you are comfortable using one first. Some people have difficulty refocusing and it may not feel natural.
- Benny
FinnCustomKnives
Woodstock, GA
- Benny
100% agreed. It can be a bit odd if not used to it.
Do you know if the auto dimming mirror retrofit requires the 8.4" unit?
AllMoparParts.com
Benny
NY
2018 JL
Will a BCM flash be required by the dealership?
No the mirrors are plug and play based on the feedback from the ones we have sold.
Please let me know if you have any questions.
Thanks,
-Benny
hiilong
2020 Jeep Wrangler JLU Sport S
Thanks,
-Benny
Thanks! My radio doesn’t have the auto dimming icon. Would that be needed, or will that auto dimming icon appear once I plug it in ?
AllMoparParts.com
Benny
NY
2018 JL
This I do not know, Sorry
- Benny
hiilong
Worked with Joe from Z automotive on enabling the icon on the uconnect. He knew exactly what needed to be done and programmed mine using a bcm flash. He said it would be easy to incorporate into a future release. He also enabled off road pages on my self upgraded uconnect 8.4.
I just installed mine but actually don’t have the mirror icon and couldn’t get it to work. Where did you go to reach out for support on this topic?
Thanks!
Next Venture Motorsports
