Odd behavior from Aux Switches
offcamber
Bob
Dallas, TX
2012 Wrangler Unlimited Rubicon, 2014 Grand Cherokee Limited Ecodiesel
  • Thread starter
  • Banned
  • #1
I originally wired my Baja Designs LP9 Pros to my factory aux switches. Aux 3 is the running light, Aux 1 is low beam and Aux 2 is high beam. It's worked fine for me until a couple of days ago. Now whether I hit Aux 1 or 2, it triggers the high beam. The low beam does't trigger. I checked the wires with a meter and when I press Aux 1 or 2, the wire going to the high beam circuit goes hot, but the low beam wire never does. Anyone seen it malfunction like that. Aux 1 lights up like it's on, but it's sending power to the Aux 2 wire instead.
WAOLIFE
Adrian & Josie
So Cal
2019 JLUM - 3.6L - Sky Touch & 2015 WK2O - 3.6L - IG: @wa0life
Fiddler of Parts
Sounds like a short either in the wiring or the lights themselves?
Did you buy the wiring harness or make it?
offcamber
offcamber
Bob
Dallas, TX
  • Thread starter
  • Banned
  • #3
Its a BD harness, I just cut the switch and relay out of it.
WAOLIFE
Adrian & Josie
So Cal
Fiddler of Parts
Unlikely that the Jeep factory wiring is crossed, but you never know.
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Where did you test the wires? Factory AUX has leads on the inside and hood. Might check both locations to ensure that it’s a “factory” issue.
