ODB Jscan available for JL
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, JTuRD
So, got a message from JScan last night.
Hopefully there will be an update out soon.
Gregj
df007
2019 JLU Sahara 2.0
Gregj
Sweet! Thanks. I hold out and see if they add the feature.
df007
2019 JLU Sahara 2.0
With regards to this:
"* OBDLink MX+ adapter is needed for full capabilities, but almost everything will work with any of the supported adapters. The MX+ is needed to access RADIO, AMPLIFIER, HAVAC and BLIND SPOT modules. All adaptations can be performed with a normal adapter, however some adaptations (such as activating rear view camera) need a radio reset, and without the MX+ this will have to be done manually"
Sounds like it is not required as long as the radio is reset after changing something. Does anyone know the proper way to do a manual radio reset?
Portmod7
Porter
Aztec, NM
2020 JLUR 2.0
Mechanic
I assume this will allow axle ratio adjustment? I haven't seen it specifically mentioned anywhere. And how bout swaybar disconnect in 2wd, as well as higher speeds?
Thanks!
Deke
2019 JLU 6.7
You can change axle ratio and t-case ratios with it. Not sure about the sway bar disco but it has a demo mode where you can download the app and look through all the settings before buying a license.
Portmod7
Porter
Aztec, NM
2020 JLUR 2.0
Mechanic
Cool, thank you!
72Blazer
The Real South Texas
72BlazerCrawler 72Blazer12V 88SBDuramax 18JLUR
SLP
Very excited about finding this thread. I've run vag-com tools on previous vehicles for years and greatly missing having that access on the JLU.
Does anyone have a picture of the bypass cable installed under the dash? I'm trying to understand what is needed before I start purchasing things.
the cable was linked via Amazon on the first page. Attaching a pic.
Just picked mine up. Going to be messing with settings when we do tires next week. Open to any worthwhile adjustments anyone else has made.
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
Appreciate your post. I was actually looking for a picture under the dash with the cables attached. However, I have since found pictures showing this detail
jludave
The Isle of Long
IT Manager
Enable the option to have your fog lights stay on when your high beams are on.
Vehicle User Settings --> Front Fog Lamp Dropout Enable On/Off --> Target Value = Deactivated
Redneck_Jedi
Currently Roaming
2019 Jeep Wrangler Sport S 2 Dr.
Does anyone know if JSCAN can disable Start-Stop?
Deke
2019 JLU 6.7
Anybody see the new HALO options in the latest Jscan? I have no idea what these features A, B and C are or what they do.
