@Gregj
Were you ever able to check the settings for your factory halos?
Brand new Jeep Gladiator Overland North Edition picked up from the dealer 04/17/2020, Factory LED Package. 42 miles on it@Gregj Can you confirm that the Jeep you are reading came from the factory with the LED package? Just checking in case they were an upgrade.
Wow sweet. You are becoming a collector! Congrats and thanks for the info.Brand new Jeep Gladiator Overland North Edition picked up from the dealer 04/17/2020, Factory LED Package. 42 miles on it
Gregj
Doesn’t look like it would. Plugs look completely different if you reference the picture on page 1 or 2.Would this cable work for Jscan? I used it on my truck and hopefully don't have to buy a separate cable
https://www.amazon.com/dp/B01F0GVBWY/ref=cm_sw_r_em_apa_i_9wkZEbR5TQVQW
Did you figure out if it'll do the sway bars in 2wd?I assume this will allow axle ratio adjustment? I haven't seen it specifically mentioned anywhere. And how bout swaybar disconnect in 2wd, as well as higher speeds?
Thanks!
OBDLink MX+ is supported on both Jscan and ForScan so I thought it might work. But JScan is IOS/Android only and my OBD device is USB-A which won't work on a phone. So regardless I have to buy something ...Doesn’t look like it would. Plugs look completely different if you reference the picture on page 1 or 2.
