Oculus™ Bi-LED Projector Headlights for Jeep JL
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Introducing the all-new Oculus™ Bi-LED Headlights (#5839-504) by ORACLE Lighting!
This direct-fit 9-inch headlight upgrade features advanced LED projection with 3,200 Lumens of high-quality illumination for enhanced driver visibility in all weather conditions. With plug-and-play installation, the LED light source has lower power demands compared to the factory lamps while providing more light output.
Features:
Precision LED lighting projector for optimum light distribution and beam angle. Installs using original mounting hardware and headlight wiring is Plug & Play into the factory connector without additional relays or harnesses. Halo DRL features over 200 bright white LEDs for a vivid lighting impact.
Benefits:
These all-new headlamps provide enhanced driver visibility with increased and focused LED light output. Complete headlight replacement, better light focus than a simple bulb upgrade. Package includes tool for easy beam angle adjustability for proper light focus on lifted Jeeps.
Safety:
Light focus is very important for not only driver safety but others on the road who can potentially have their vision obstructed by glare. This is especially significant on lifted vehicles where the light source is raised and in a position to interfere with the field of vision of other drivers. These new Oculus headlights feature a very sharp cut-off line and focus light with precision specifically to avoid such issues.
Reliability:
It is undeniably important to implement proper thermal management tools for high-performance LEDs to operate with reliability in various environments. Oculus utilizes both active and passive cooling methods to sustain low LED temperatures. Remote mounted heat sinks and an internal cooling fan work in conjunction to insure proper temperature control and longevity of the LEDs.
Specifications:
Wattage: 36W
Total Lumens: 4800LM
Color Temp: 5500K
Certification: DOT SAE 5839-504 HL VOR 19
Warranty: 2 Years
Fitment: 2018-2020 Jeep Wrangler JL & 2020 Jeep Gladiator JT
GET YOURS NOW!
ORACLElights
ORACLElights
Metairie, LA
FORUM EXCLUSIVE SALE:
Black Friday wiped out our Oculus stock...but we got you! Our next shipment is on its way and will be shipping on December 18.
We want to give you first dibs before we sell out again!
PM us or call our forum sales rep, Melissa, at 504-322-4094 asap to get 10% off the Oculus AND free USA second-day air shipping on December 18 to get them in time for Christmas!
ORACLElights
ORACLElights
Metairie, LA
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
how about with OEM LED package wrangler's ?
do we need to Re-program or its Plug and Play also ?
ORACLElights
ORACLElights
Metairie, LA
It's the same plug so you'll have the same easy plug-and-play install. :rock:
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
2018 JLU Rubicon, 2014 JK Willys, 1999 TJ Sport, 1966 CJ5-A
These things are great. Here is a install / review video of them.
kjphilips
Kevin
Michigan
Wrangler JLU Sport
thinking about buying a pair, are they waterproof?
ORACLElights
ORACLElights
Metairie, LA
These lights are designed for all weather conditions and feature the same type of venting system as the factory LED lights. These are not designed to be submerged (no headlights are) but other than that caveat, YES they are waterproof.
Doctorit
MA
2018 JLUS
So far so good!
Install was easy, kit was great (although, the red pigtail wire to the fuse box could have been a little longer), and after some height adjustment and getting used to that sharp cutoff, I can see much better.
Excellent service from Oracle, throughout!
Doctorit
MA
2018 JLUS
One quick followup question (to Oracle): will the color temperature of your DRL LED replacement bulbs (7443 18 SMD) match the Oculus halos?
This is very important, I can't be driving around with mismatched DRL colors! ;)
ORACLElights
ORACLElights
Metairie, LA
Yes, they both are the same color temperature :like:
Caleb75
Caleb
Upstate South Carolina
2020 JLU Altitude
I have 2020 JLU Altitude with stock halogen.
Does your kit come with everything I would need to hook up the DRL Halo and detailed instructions? Is there a forum discount?
Your product looks great!
ORACLElights
ORACLElights
Metairie, LA
Hi Caleb, everything is included with the Oculus so it's a simple install. Check out the install video here. We do have a forum discount! Use code forum10 at checkout + we offer free USA shipping!
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Part of the Northridge4x4 team
The install was very easy, they look great and they are bright! Nice product Justin and crew!
