Occasional flashing brake and ABS light after 35" tires
1fastss
Mickey
Greeley, CO
2021 Jeep Wrangler
I replaced my factory wheels/tires with 35". I have experienced the brake and ABS light flashing while sitting at a stoplight a few times. When the light is flashing the brake pedal becomes somewhat stiff. Anyone have similar issues after replacing wheels and tires?
Ruby Mike
Southern California
2020 jeep wrangler diesel
Sorry to hear about your issue with the lights. So far I have no problems after going to 35 inch tires. I have about 7k on the cooper mt and love them. Wish I could help you.
Ruby Mike
Southern California
Did you use anything to adjust tire size at all?
The only thing I did was to recalibrate the speedometer. I replaced the stock suspension with the GC 3.5 but that has nothing to do with tire size. I wish you luck.
gm920
Gary
San Diego County Mountains
2019 Jeep Wrangler JLUR Billet Silver
Aircraft Maintenance Technician (Retired)
Do you have a Tazer JL installed?
gm920
Gary
Yes, I have the Tazer installed
That's the brake hold feature of the Tazer, you are using more brake pedal pressure than necessary to keep the Jeep stopped. That's what activates "Brake Hold", releases as soon as you touch the accelerator, or I believe after 2 minuets. Lights are flashing to let you know it's on. Very nice feature I like it.
Robellion
Eric
New York State
2022 Jeep Wrangler Rubicon
Yes- brake hold. This issue was discussed a few weeks ago. When installing the Tazer, it is programmed out of the box to have the brake hold feature ON. This is a mistake I'm sure that ZAuto will fix in the next firmware version- but it has caused a lot of confusion and troubleshooting to figure out the culprit of the lights flashing. Zauto...you out there? Anyway, just turn that feature off and do the reboot thing.
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
I believe its a "live feature" so you can turn it on and off as needed/wanted.
1fastss
1fastss
Mickey
Greeley, CO
2021 Jeep Wrangler
Thanks everyone. I appreciate the input.
gm920
Gary
Why is it a mistake? If you read the instructions there should be no surprises. I find it to be a very useful feature and those that don't like it can turn it off. I have never had brake hold activate when stopping unless I make a conscious effort to apply extra pressure to the brake pedal.
entropy
Foothills of the San Gabriels
Jeep Wrangler Sport S JL 2-D
I dont even understand what this feature does. Anyone cares to explain?
on another side note, my tazer JL does weird stuff sometimes. Since 2 days ago it flipped my tpms sensors showing the left front tire as the right rear tire. very annoying. Last month I turned off my Jeep while on 4lo and on the freeway while on 2wd it would keep turning traction control off.
Robellion
Eric
New York State
A feature involving the brakes that is not a standard factory equipped one, then unexpectedly show up after the Zauto is installed could be perceived as a mistake on the programming end. I'm not saying it's not useful- it just should be programmed in the off mode out of the box, making the user turn it on. Thus ensuring that the user knows the feature and giving them the power to turn it on. Most people had to dig to even find out why it was happening.
gm920
Gary
I understand your point, but don't agree. I realize that some people buy the Tazer only to change tire size or gear ratios and turn off the ESS. The Brake Hold along with all the other features are clearly described in the instructions, so again there should be no surprises or digging to find out what's happening. You have to step through all the menu items during installation, would it not makes sense to look and see how they are set?
