OBDLink MX+ OBD2 Bluetooth Scanner - UPDATE it's Firmware
Rhinebeck01
2018 2dr. Rubi
Many of you own a OBDLink MX+ OBD2 Bluetooth Scanner and use it with JSCAN to deal with your JL/JT....
When you get a chance
, with your OBDLink MX+ OBD2 Bluetooth Scanner , and it's associated OBDLink app that comes with it....
DO, update the OBDLink MX+ OBD2 Bluetooth Scanner's firmware.
You will, while in the OBDLink app, register the scanner with OBD Solutions, LLC and the app will then load profiles for your year JL/JT.... based on your model year and Vin#.
After that firmware update the OBDLink MX+ OBD2 Bluetooth Scanner FIRMWARE..
It is prudent to occasionally check to see if your scanner tool has the most current firmware.... It only takes a minute to do.
IMPORTANT ..... when doing the firmware update to the OBDLink scanner do not unplug the scanner or turn your JL/JT off..
Here is a video that will give you an idea what/how to do the above..
Rhinebeck01
Rhinebeck01
2018 2dr. Rubi
Forgot to mention...
For the OBDLink MX+ OBD2 Bluetooth Scanner
You can go here and see what the current firmware release version is, and the date that version was released and the Level of Importance of that release.
TopLift Pros
