- Dan
- Jan 9, 2018
- Grand Junction , Colorado
- Website
- www.nextventuremotorsports.com
- 1949 Willys VJ, 1973 Jeep Commando, 18 JL , 21 JT
- Occupation
- CAD Designer, Adventure Machine Outfitter
Next up is a bumper built to match the high clearance angles and styling of our adventure series rear bumpers!
These bumpers are crafted from a combination of 1/4", 3/16" and 1" thick steel (for the machined d-ring tabs of course!) to give your Jeep the light weight, but stout-where-it-counts bumper it deserves! The machined recovery tabs are welded to the winch plate of this bumper which is bolted directly to the frame rails.
The internal tray/winch plate is a single piece of 1/4" steel has been laser cut and precisely CNC formed. This tray will accept all width's of the NV Adventures Series Front Bumpers if you decide to try a different width bumper in the future. The winch tray locates the winch between the JL framerails for unimpeded airflow to the radiator, and a lower center of gravity vs winch mounts above the frame rails.
Optional Winch Delete Tray can be optioned as stainless steel, or 1/8" mild steel. This is recommended for a "complete look" if opting to run the bumper without a winch.
Light provisions are designed for a 3x3 LED Cube.
Bumper is shipped bare metal unless ordered with powder coat. Bare metal products may have scratches/surface imperfections from raw material handling/manufacturing/fabrication that are easily covered up with a textured powder coat. Additional finishing/sanding/prep work will likely be required if you wish to have them finished in a smooth coat or paint.
EST. SHIPPING DATE OF OCT 1.
https://www.nextventuremotorsports.com/product/jl-mwfrontbumper10/
