AVGeek99
- Chris
- Aug 24, 2021
- Delano, MN
- 2021 JLUR, 2021 Sahara 4xe (wife's)
I've had my Jeep 11 months today. I went over 20,000 miles today. I have had zero problems to date, until today. After a day of fun, my clutch appears to have issues, and it won't even turn over. Sorry for the long post, but I assume something I did today is causing, or at least contributing to my issue. Here's my day...
Today started out really fun. Went to 4-Fest MN, ran a bunch of trails. Played in the mud (pics below) and gravel pits where they had made some obstacles. Then later in the afternoon I started having some issues.
After playing in the mud we were on some other trails. I noticed the temp gauge was running warm. Until today I had never seen it go above normal. I monitored closely and it kept climbing so we got off the trail. We headed for the car wash, I was thinking maybe I got some mud in the radiator. On the way to the car wash, about six miles, the temp guage maxed out. It was maxed out for about 1.5 miles but we got to the car wash ok.
I washed the exterior spraying a lot of water into the radiator. Then I lifted the hod and there was mud everywhere, so I carefully cleaned the engine compartment careful not to directly spray electrical stuff. When I was done we headed back to 4-Fest. For the entire 6 miles the temp guage had it's normal reading. As soon as we got off the highway, driving slower through the OHV park, the temp started to climb again. Back to the car wash I went to clean the radiator from the inside.
At this point I remembered the actual coolant temp gauge. On the 6 mile trip back to the car wash it climbed to a max of 275. Hovered between 270 and 275 for the last 2 miles, but ran fine and didn't give any issues. I should make it clear that up to this point, the only problem was the overheating. Throughout all of this the Jeep ran fine with no dashlights, just the engine high temp warning anytime the coolant temp went above 255. We made it to the carwash and I cleaned the radiator from the inside this time.
Then we headed home, about 50 minutes. The whole way home I was keeping check on the coolant temp. For the most part hovered between 220 and 225. The warmest it got was 230, coolest was about 210. The fan was running as it should only turning off when it got below about 212 +/-. The temp guage never went beyond the normal reading, just under half.
On the way home I noticed the clutch got softer than normal, and it wouldn't go all the way to the floor like normal. It would stop about two inches from the floor, and would go further if I pressed really hard. Then I noticed it was getting more difficult to shift into gear. Downshifting when slowing down was a little easier, but when accelerating, 2nd through 5th were much more difficult than normal to engage.
We made it home fine, the Jeep ran great the whole way. Once home I figured I'd clean it a little better. I cleaned the under carriage. I also pulled the air filter off and moved the air intake out of the way so I could get at the radiator better to give it one final cleaning.
Once done I got into start it and put it in the garage... and nothing. All the electrical seems fine, but it doesn't even attempt to turn over. When I press the ignition button it's really kind of acting like I don't have the clutch depressed. One push to 'Acc', a second push to 'Run', third press turns it off. I have one foot on the brake, the other on the clutch as per usual, but it doesn't do anything, not even any clicks. I do notice that if I leave it in Run there is an audible highish pitched tone coming from the engine compartment. I think it's coming from the driver side back near the firewall. The tone only happens when in the ignition is in 'Run'. Doesn't do it in 'Acc'
For the night it is just sitting in the driveway. I'm hoping it will start in the morning.
Anyone have any ideas on what may be happening?
