Moblrn
If it's odometer range and not actual miles I would agree, but if you can't make it to the same spot on electric as you did the day before it's due to the new tires and wheels.If you want to stay with the 35’s, Toyo AT3-35/12.50/17/C—59lbs , 285/75/C-also 59 lbs although .6”shorter and more narrow, If you want to sell yours and swap. Edit— recalibrate?— going from 32.8” to 34.5” tires my speedometer is 3.5 mph slow at 65 mph (actual 68.5) so indicated mpg will be less than actual. Indicated range would be similarly effected, but not as much as you are saying.
I put some take off KO2's and wheels on my 2019 Sport, but took them off a couple days later due to the changes in MPG, ride and driving characteristics. Still liked the wheels so I just switched back to the "Stock" tires.
If I had the space, I'd have daily commute tires and wheels and then a set of something for inclement weather and playing around off the paved roads. Maybe someday.
Rod
