North Carolina Roll Call
Ran4
Randy
Port Saint Luce FL and Charlotte, NC
2019 Sahara Unlimited
Ball Joints are labeled for Upper and Lower and the orientation of them is important for the grease fitting access.
Jeep Wrangler JL North Carolina Roll Call 07A30607-FE30-4A32-B4E8-8121B63848EF
Thanks Shawn. Having the peace-of-mind knowing the job is done right makes the drive from Charlotte worth it. The Teraflex ball joints look like the real deal..:).
Sean L
Sean
North Carolina
my negative battery cable will not tighten down on the post to save my life. What a shitty design. Anyone else have this problem?
Yep... snapped the "bolt" right off of mine... :headbang:
mgroeger
Hurricane, UT
Running the Rubicon Trail June 15th if anyone is interested. It's just a 10 hour drive from our house. If it sounds like I'm bragging... it's because I am. Mic Drop.
MerPinXEss
Kdale NC
‘24 4xe JLU
Topless Day: hope to see lots of topless jeeps
We Plan on heading to Ft. Fisher this Saturday, 5/21, around noon, and setting up in front of the first cut off after the entrance/Zeke’s Island Reserve. Gonna be 83° and sunny! Top will be off to celebrate National Go Topless day! Although our get together isn’t a fundraiser, please consider donating to one. There are a lot of good causes out there.
mgroeger
Hurricane, UT
conFUcius
Stephen
North Carolina
2020 Sting-Gray JLU Rubicon 3.6 V6
Medical Affairs
I sure do hope they explain what Go Topless Day means to the peeps in FV. You're liable to get lots of boobs and a few teeth. Disclaimer: I used to live in FV
I don’t know about you but I prefer when the boobs come with teeth… not into meth heads :giggle:
mgroeger
Hurricane, UT
RoccoV
Rocco
North Carolina
2018 JLU Sahara
I don't live there but go to the area often. It has changed a ton in the last 5 to 7 years for sure. But in certain areas you still will see a little of both happening. :CWL:
Remorseless
NC
'22 JLR 2.0T, '21 KL TH 3.2, '19 Charger R/T 5.7
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast
Glad to see a lively NC thread here!
Quick question for those of you that've made it to Uwharrie this season - how's Wolf's Den doing with the rutting? By the end of last season Wolf's Den was so slopped out that my JKR couldn't make the hill climb after that sharp left due to being on KO2s (holdover from when it was a DD, 37s are expensive to replace lol, MTs only for the JL, third vehicles are nice). Last couple times we were there we had lines of people being recovered - never thought I'd see that on Wolf's Den, but here we are, what a world.
Anyway, my JK is gone and I'm in a stock JLR on MTs, but with the lower diff-to-ground clearance I'm trying to figure out what to expect this season since we usually run Wolf's Den as a warmup trail. Never thought in a stock Jeep I'd be more worried about Wolf's Den than Dickey Bell lmao. I'm not sure how much work they've been getting in during the off season due to all the craziness with covid and supply chain stuff, but hoping one of y'all has run it recently.
