chevymitchell
- Shawn
- Feb 18, 2018
- K-ville, NC
- 2019 JLUR (Pain Train), 2022 2500 AT4
- Occupation
- Avi Engineer
That honestly doesn't look too bad at all. Some scrapes and whatnot isn't going to hurt anything. If it's gouged or dented, then I'd say definitely replace it.@chevymitchell this is a good excuse to call Oliver’s, right?
We have the FT TCase, I keep seeing issues with 1350s, thoughts on running 1310s? Stock 4.10s, 37s.
I wouldn't worry about the 1350 if you go that route. Oliver's uses a strap yoke on the transfer case side instead of a flat, prop yoke. There's lots of room next to the oil cooler. I run a 1350 front shaft. You'd be ok running a 1310, but if you're spending the money, then definitely upgrade the joint size while you're doing it.
