Normal to need to turn wheel 360 - 540 degrees for a 90 degree turn?
  1. nilyogi
    nilyogi Member
    First Name:
    Reed
    Vehicle(s):
    2-Door JL 2019
    Feb 9, 2020
    Atlanta
    Liked:
    Steering this car is quite a cumbersome task and and Im not sure if its normal.
    Turning the steering wheel feels like it requires an unusual amount of effort and the amount needed to turn the wheel seems exaggerated. I often find the wheel fully turned around twice (720 degrees) after making certain turns, and almost every turn requires atleast a 360-540 degree revolution. The steering wheel will also jerk quite far in certain directions when hitting bumps. Is this normal? Also there seems to be about an inch I can turn it in either direction before the car actually starts responding and this seems to happen regardless of starting a turn or coming out of one. I just came from driving a 2017 Giulia so there is obviously going to be a pretty big difference so maybe it just feels more exaggerated because of that. Is this normal for these JLs or not?
  2. Mikeoso
    Mikeoso Well-Known Member
    First Name:
    Vehicle(s):
    2006 Ram 1500 2019 Jl Sport
    Jul 6, 2019
    Iowa
    785
    Liked:
    5,280
    Occupation:
    Retired history teacher
    Absolutely NOT normal, or even close to it, and dangerous as well. Get it into a tech or dealer immediately.
    RagTopDeluxe and MeanMrWolf like this.
  3. beaups
    beaups Well-Known Member
    First Name:
    Sean
    Vehicle(s):
    2020 JL
    Dec 6, 2019
    Ohio
    191
    Liked:
    183
    You aren't driving around in 4WD mode are you? That could cause a bit of what you are experiencing. While there may be an actual issue, keep in mind your previous car has the highest steering ratio of any production car (as did I), so you are going from one extreme to the other, to a certain degree.
  4. OP
    nilyogi
    nilyogi Member
    First Name:
    Reed
    Vehicle(s):
    2-Door JL 2019
    Feb 9, 2020
    Atlanta
    Liked:
    im interested in what peoples actual experience driving their JLs is. does the wheel take a lot of effort to turn? Do you have to turn the wheel around 1.5x to take a 90 degree turn? When you hit bumps does it pull the steering wheel several inches to the left or right?
  5. Mikeoso
    First Name:
    Vehicle(s):
    Jul 6, 2019
    Iowa
    785
    Liked:
    5,280
    Occupation:
    ok, I have a 2019 JL Sport, 2 door, all stock. It doesnt take much effort at all to turn my steering wheel, and a 90 degree turn (like a street corner) needs about 50 degrees of wheel. My wheel doesnt pull at all when I hit bump.
    If it's doing what you describe, something is badly wrong up front, and seriously, the only place I would drive it is back where I bought it.
    Notorious, Arterius2 and beaups like this.
  6. Apoznan
    Apoznan Active Member
    First Name:
    Andrew
    Vehicle(s):
    2020 Sahara
    Aug 1, 2019
    Staten Island
    Liked:
    33
    I just tested mine. If I'm making an extremely sharp turn, and I make an effort to turn as much as possible, I'll hit 270 degrees, or 3/4 of a turn. Get yours checked bud.
  7. cOtter
    cOtter Well-Known Member
    First Name:
    Vehicle(s):
    ‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
    Aug 6, 2019
    Southern, Indiana
    415
    Liked:
    593
    Occupation:
    Senior Manager PM (Automotive OEM)
    Not normal at all.
  8. jdubya421
    jdubya421 Well-Known Member
    First Name:
    Jakob
    Vehicle(s):
    2019 JL Sport S 2-Door
    Jul 24, 2019
    Greensboro, NC
    220
    Liked:
    235
    As everyone said, not normal. The steering on the JL is surprisingly light.
    Notorious likes this.
  9. JeepCares
    JeepCares Well-Known Member
    Vehicle(s):
    JL
    Feb 1, 2018
    Auburn Hills, MI
    3,248
    Liked:
    1,309
    @nilyogi,
    We certainly recommend having this looked at by your dealer. Please reach out to us privately if you require any additional assistance during your service.
    Kathryn
    JeepCares
Loading...
Share This Page
