F800
I ended up wiring two switches directly below the headlight/dimmer controls. It made the most sense to me to put my auxiliary light switches in this area. I only wired two switches, but it looked like there may be enough room for 1 or 2 more. There is no need to remove the entire dash to get to this area.
The headlight controller comes out very easy with a trim removal tool. You can see there's a face plate, followed by the control panel, which has 4 metal clips that hold it in place. Once you pull the panel out, you will be able to unplug the wiring harness by pushing the red tab up and pulling it apart.
I also removed the knee panel below the steering wheel so I could run my wires easier. The panel is held together with clips and comes out relatively easy. Once the headlight controller was removed, I made a template and traced where my holes were going to be. I made sure the wiring wouldn't rub on the headlight controller, once installed. You will have just enough room to wire the switches....unless you have fat hands and/or fat fingers. Good luck. Have patience.
Some tips: wire your switches from bottom to top so you have more room to work. Also if you're going to use a dremel to drill your holes, don't slip like I did and scratch your panel.
Is this basically the same thing that you used?
Nilight NIL102 Off Road ATV/Jeep LED Light Bar Wiring Harness Kit 40 Amp Relay On/Off Switch https://www.amazon.ca/dp/B0155W7EDS...t_i_BFXB1BF2TFYMA4BQ2KYR?_encoding=UTF8&psc=1
