Non-LED to LED Fender Light Question
Jcarrig3
Jamie
2018 Ocean Blue JLUR
I just bought some LED Fender lights to replace my Non-LED fender lights. I have not pulled my fender apart to double check yet, but The guy I bought them from said that I would need to get a different wiring harness to plug them into. I have searched Google and I can't find any info on the wire harness that I would need.
Does anyone have any knowledge or experience with this?
Thanks!
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Are they aftermarket lights that are designed to replace the halogen fender lights as a whole assembly? Or did you somehow harvest the OEM LED lights from someone's fenders?
Jcarrig3
Jcarrig3
Jamie
Sorry I should have clarified that.. they are OEM lights that someone took off of their Jeep to do the Artec Fender Chop.
mwilk012
Oklahoma
Service
I have a feeling you're going to have a hard time with that, he is correct that the wiring is completely different.
Jcarrig3
Jcarrig3
Jamie
jlsahara
Oscar
AZ
2018 JLU
mwilk012
Oklahoma
Service
How much wiring is attached to the lights that you have? Do you have a picture?
Jcarrig3
Jcarrig3
Jamie
The marker lights have a pig tail attached but the turn signals do not.
mwilk012
Oklahoma
Service
Oh wow that is really torn apart. The marker lights should be exactly the same as what you already have installed, but I have no more information on those turn/DRL's. Can't even tell by looking at it where to plug it in.
Jcarrig3
Jcarrig3
Jamie
There is a hole on the back where the harness goes. It looks like the same opening where the bulbs go. On the LED lights instead of a socket where the harness attached to the lens housing there should be a connector..
I ordered the 68315806AB harnesses from the dealer. It turns out thpat part number goes to the non LED lights. The dealer and the guy I bought the lights from are trying to find The right part number for me. In their system the harness is part of the LED lamp assembly, so it could be a challenge.
rkyle
Kyle
Ridgefield, Wa
JLUR Wrangler
I got a set of the same OEM takeoffs to replace my factory halogens. The guy I bought them from gave me both fenders as well with the pigtails attached. They do plug directly in to where your halogens do. However, you’ll have to get your software flashed or get a tazer. If you don’t have the factory LED package, it will screw up both front and rear blinkers. I had the dealer flash. It cost about $150 at the dealer I went to.
4xnaz
Tim
Phoenix, AZ
www.instagram.com
2018 JLU Rubicon
Here is a shot of the back of my LED take offs that I have sold. The harness has a 5 wire plug that mounts to the area where a halogen bulb would be. Sorry but I dont have a part number for the wire harness.
Jcarrig3
Jcarrig3
Jamie
No, not yet. I am in the process of trying to find the right molex connectors to make my own wiring harness. I will let you know if I am able to get it sorted out.
Bingg
Bing
Los Angeles
2018 Jeep Wrangler Sahara
I’m trying to buy it from one guy but I’m not sure if it fits, im having the same problem as you, wonder if you ever got it to work.
