Rodeoflyer
- Bert
- Dec 16, 2019
- Conifer, Colorado
- 2020 Jeep JLUR; 2016 Ram Powerwagon
- Vehicle Showcase
- 1
go
If you have a rubicon, the RK no limits end links are what I use. They are made specifically for the elect disco. IMO , it’s the best you can do without disconnecting the old fashioned way. You can see how much misalignment there is when flexing.
The same here. They have my voteIf you have a rubicon, the RK no limits end links are what I use. They are made specifically for the elect disco. IMO , it’s the best you can do without disconnecting the old fashioned way. You can see how much misalignment there is when flexing.
Both great companies, I’m partial to RK. Whichever end links you get , you’ll need a minimum of 2” lift to use them. Claytons might be 2.5 “ minimum height, not sure.I want to decide on a lift company (still stock with Synergy trackbars). I'm leaning towards Rock Krawler or Clayton. Leaning towards these https://www.claytonoffroad.com/product/jeep-wrangler-adjustable-front-sway-bar-end-links-2018-jl
Compare between the two. I think you'll find that the heims on the rock krawler sway bar links allow for considerably more articulation angles when you have one wheel high and one low. That's their claim anywayI want to decide on a lift company (still stock with Synergy trackbars). I'm leaning towards Rock Krawler or Clayton. Leaning towards these https://www.claytonoffroad.com/product/jeep-wrangler-adjustable-front-sway-bar-end-links-2018-jl
Take a look at AccuTune as they also have a heim joint style that has similar misalignment as RK. And significantly cheaper, but I will admit not as sexy.I want to decide on a lift company (still stock with Synergy trackbars). I'm leaning towards Rock Krawler or Clayton. Leaning towards these https://www.claytonoffroad.com/product/jeep-wrangler-adjustable-front-sway-bar-end-links-2018-jl
They are indestructible. If you hold one in your hand you'll understand.$300?! They made out of melted down wolverine claws?
If you wheel it.....it’s worth it.......$300?! They made out of melted down wolverine claws?
I do. still crazy expensive though.If you wheel it.....it’s worth it.......
I snapped the MetalCloak upper bolt on their end links 5 times with crazy articulation demands. They did replace every one. That's said, the rock crawlers have been in place for well over 12 hyper duty off road trips. Not one issue.I do. still crazy expensive though.
