Bowhunter23
I've searched around and haven't seen a direct answer. Other than loss of height, is there any concern running non-4XE lift springs on a 4XE Rubicon? I know the Mopar lift only gives 1" of lift on a Rubicon 4XE. Is the Mopar lift I see people putting on 4XEs the same as the 2" standard lift? Anyone else using other aftermarket lift springs on a 4XE? Looking for roughly a 1.5" spring lift (absolute max of 2" lift) on my 4XE Rubicon and all of the 4XE specific lift kits out there start at 2.5" and most state that you can see even more than that because they are designed with winch/bumper and heavy spare tire. I'm already running 1.5" spacers and with winch, bumper, tailgate reinforcement, and spare tire it's sitting at only 3/4" overall lift from the compression of the stock springs. Since I have all that stuff, I'd probably be around the 2.5" lift but that's still 1/2"-1" taller than I really want to be. Don't want to mess with front driveshaft, adjustable LCAs, etc, want to be able to still be able to put a kayak on the roofrack without needing a ladder, and I have small kids that need to climb up in the backseat. I really don't want to go to a 2.5-3" spacer (if those are even available) to net 1.5-2" and would rather find springs that give 1.5" lift. Would standard JLU Rubicon 2.5" springs net a 1.5" lift on a 4XE or would the spring rate be totally off and ride like crap?
Seems odd that nobody offers a 1.5" spring lift for 4XEs. Is the general consensus to just use spacers for anything less than 2.5". I think I read that 4XE Rubicon rear spring rates are something like 170 #/in. Aftermarket lift companies don't readily state their lift spring rates. I'm thinking as long as the lift springs are at least 170 #/in and just taller, the ride should stay similar to stock like spacers but with the added benefit of longer springs.
