Noise from front wheel/axle
JlRubicon13
Davi
2 door wrangler rubicon
Hello so I recently raised the Jeep and spun the wheel with my hand. This is the noise that the wheel|axle area is making. Is this normal? Jeep is in 2wd and is the front axle. Only driver wheel is this loud. Passenger side the noise is much quieter, almost non existent.
CalsJLUR
Trey
Lenexa, KS
2018 Wrangler Unlimited Rubicon
Have you checked the u-joint?
limeade
Guy
Reno, NV
Sounds normal to me. If you spin the rears they will make the same noise.
JlRubicon13
JlRubicon13
Davi
Ok only one of the wheels on the front axle makes the noise. The passenger wheel is almost non existent. Here’s a video from the passenger wheel.
limeade
Guy
Reno, NV
The front driver side axle shaft goes right into the spider gears in the differential. The passenger side shaft is disconnected at the FAD, therefore the gears aren't turning. IMO, what you're hearing on the driver side is the rotation of the axle shaft and the spider gears and you won't hear that on the passenger side.
Put it in 4Hi and see if the sound is same/similar for each side.
JlRubicon13
JlRubicon13
Davi
That makes sense, thank you. I’ll check in 4hi in the morning.
limeade
Guy
Reno, NV
You're welcome. It's been awhile since I spun my wheels like that, but that's what I remember it doing. Each of the rear will do it too, since each shaft goes directly into the diff.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
When you spin one wheel at a time, the entire differential third member is rotating, that’s 6 gears meshing and spinning around. If it’s not making a noise while driving, it’s fine.
service the fluid anyway.
JlRubicon13
JlRubicon13
Davi
Ok thanks. Yea no noise while driving.
