No volume from Alpine radio
sna77
Boston
Hi all--
I got into my 19 JLU Rubicon this am--there is no volume output from the radio at all. Mute is not on. Regardless of the source, I don't get any sound. Have tried with FM/AM, Sirius, Bluetooth phone, USB media drive, disconnecting Bluetooth/ everything... Turned the car off for 15 min and tried again... No luck.
Any quick fixes on this, or am I scheduling a dealer appointment?
Thanks!
Killed by Death
North Carolina, USA
Sarge Green 2021 Rubicon 2 Door
Hi all--
Thanks!
This has happened to me 3 times. Switching to AM and then back is the only thing that has worked.
Rploaded
Houston
2019 JLUR
Turn off and back on or switch to radio and then go back.
Ntegtmeyer
Nathan
Aurora, IL
2018 Jeep Wrangler Sahara, 2014 Jeep Grand Cherokee Summit, 2014 Jeep Patriot Oscar Mike Edition, 2012 Jeep Compass Limited
Go under your hood in your fuse box and pull the fuse for the radio, that's the equivalent of a hard reset and that should fix your issue.
JeepCares
Auburn Hills, MI
JL
Hi all--
Thanks!
Hi sna77,
I am so sorry to read about this! Were you able to get everything working again? Feel free to send us a message if you'd like to discuss further.
Kaitlin
Jeep Cares
Weedwacker
Tim
Newnan
Harley
Alpine system has three fuses. Double check all three and make sure they are seated properly and/or not burned out.
Columbus104
Kurtis
Columbus, Ohio
2018 Wrangler Moab (white)
I've had this same thing happen, and also switching to AM worked to "reset" something. And then audio works on FM, CarPlay, etc
sna77
sna77
Boston
Came back to the car after lunch today, and the radio magically works. Groan. Can't wait till the next time this happens... Is there a software fix coming out at any point for this car system?
JeepCares
Auburn Hills, MI
JL
We can't speculate on when one is coming out, but if you have another concern with the radio please feel free to send us a message so we can look into an update or anything else that may help.
Kaitlin
Jeep Cares
Killed by Death
North Carolina, USA
I was told there is a firmware update that also includes "static" issues.
Waiting for next oil change, no biggie.
Purchased Jan 19th
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
Same here, started after the firmware update to fix the USB connection issue; which is still there just not as often.
You can tell this stuff is all really FIAT and not Jeep as fix-it-again-tony is a common theme.
Hudson
PNW
2020 JLR
I think the issue is more likely Chrysler, as the head unit is common across Chrysler. Not sure if the OS is designed in house or outsourced to a vendor. I have the same unit in my RAM.
Killed by Death
North Carolina, USA
Heard a rumor it was Panasonic but I'm lit :beer::beer::beer::beer::beer::beer:
