no power steering, battery is too low,the fan does not work.
daniel5678
2021 jlu
When I start the car, there is no power assist in the steering wheel, the battery is extremely low, and the fan is not working causing the water temperature to rise.
Finally checked the fuses and reinserted some of the loose fuses and the Jeep was fine again, but this has happened three times and I'm going to go to the dealer to have it checked thoroughly. Have any of you ever encountered this?
AVGeek99
Delano, MN
2021 JLUR, 2021 Sahara 4xe (wife's)
I would say your serpentine belt is failing, or completely broke. You're not charging so all electrical is running directly off the battery. You need to get it to a shop before your battery dies, or you'll need a tow.
Fonzilla85
AL
Ventura County, CA
2018 Jeep Wrangler JL Rubicon Unlimited
Lawman
You probably want to document this, report it to the dealer and leave it alone. Mainly saying that because of your other post talking about the “new” engine breaking again. Let the dealer take care of this, don’t do anything that may cause them to point the finger at you.
AVGeek99
Delano, MN
Didn't realize it was the same person that posted about the 2nd engine dieing. I'm confused, I thought it was at the dealer already? Either way, the symptoms listed in the subject indicate an issue with the serpentine belt.
daniel5678
daniel5678
2021 jlu
lol,You also asked me in another of my posts: "Where in Revenge Hell did the smoke take place".
Well, I always thought it was a fuse problem,
Renegade
Zac
Signal Mountain, TN
‘20 JT
Jeep Wrangler JL no power steering, battery is too low,the fan does not work. 图片_20231120222412
Did they give you a 3rd engine and this is happening?
AVGeek99
Delano, MN
But you didn't mention a fuse problem in the other thread until several pages in. You brought up Oil blowback (called it oil backflow) in your OP. I asked you "Where on Hell's Revenge..." because there's only a few obsticles where oil blowback could even be a remote possibility.
