New Wheels pro’s vs con’s- thoughts ?
2nd 392
2nd 392
Ca
Or you could have a set of Enkei RPF1s redrilled. I think the 17x8 is sub 17lbs each. Just a thought.
Another option I didn’t know, I will check it out. But 4lbs worth a redrill ? Likely not unless I really like the wheels. Thanks- options are good. 😊
Mudduck
Jay
Michigan
2021 Willys 4door
Jeep Wrangler JL New Wheels pro’s vs con’s- thoughts ? ENKEI-RPF1-GG-120-WEB-100x100
16.05 LBS
If money were no option, Id be doing this myself. However, I just went over retirement and Christmas finances..... Everyone is getting a hug as it is.
2nd 392
2nd 392
Ca
16.05 LBS
No 5X127 ? 17 X? Offset ? You have me interested.
Mudduck
Jay
Michigan
2021 Willys 4door
Theres a spec sheet somewhere, and I have the contact for a guy that can get blanks. Ill post it when I get home.
2nd 392
2nd 392
Ca
Thank you— I will see what my marginal search abilities can find.
2nd 392
2nd 392
Ca
Found a size chart , no 5x127, 30 & 40 inset - 8.5’s, weight not found…. ass u me ing 30&40 inset is mm offset.
Mudduck
Jay
Michigan
2021 Willys 4door
FM-Wheels.com. Custom offsets and drills Available.
TopWright
Richard
Western NC
2019 Rubicon JLU Granite Crystal Metallic
USMC (Ret); IT Specialist K-5 Public School
The bronze color may go well with your 392, but since you're asking opinions. I think they are a little too blingy for a Jeep. They would go better on a lowered 2wd street pickup.
But then, I prefer less flashy wheels. I just ordered a set of Method 703 wheels in matte black for my Sting Gray colored 392. They also make them in bronze.
I'm also looking at the 703 bead grip in black. They are on my list, just not sure of the offset I need. I have a 2019 JLUR. I have a 2.5" JKS lift in the garage ready to mount as soon as I get my 35" tires.
3TV
Southwest USA
2022 JLUR XR 392
Backspacing will stay the same regardless of wheel width but offset will be different even on wheels with the same backspacing, if the wheels have different widths. I don't even know if that made sense, but I tried.
In any case, I think a 0 offset on an 8.5" wide wheel is perfect for my Jeep. The tread part of the tire that actually touches the ground at highway pressure (32 psi) is completely covered by the XR fender flares. That means the outer 1/4" of tread and the sidewall bulge are past the edge of the XR flare. And there is enough offset that 37s don't rub on anything at full steering lock and full flex of the suspension. I have the stock extended XR front bump stops, and 1" extended XR rear bump stops.
