XxsullyxX123
- John
- Jun 22, 2020
- Somers, NY
- 2020 JLU Rubicon Recon, 2020 Honda Pilot Touring
Unfortunately its all buttoned back up and I didnt take pics, as I am not a big picture during installation guy. I'm more of a cursing during installation kind of guy. First off, some of the install videos have you popping the rivets out of the most exterior edge of the fender and need to replace those. DON'T DO THAT. The 3 bolts and 3 christmas tree fasteners on the fender liner itself are all that need to be done.@XxsullyxX123 I have a set on the way and I can’t wait to get them installed. I also have the LED package on my Jeep and I was wondering how you ultimately wound up wiring these lights up? Can you provide any feedback of what wires you tapped into? Any videos or pictures of the installation as well would be greatly appreciated. Electrical
Is not my thing
To your question, for the LED lights it is not the 3 wires that are referenced in the install guides. it is 2 wires that split off of a larger bundle that goes to the DRL/Blinker. if you start at the orange corner LED parking light, you will see 2 wires come off of it. Black and white (more cream colored on mine) that is taped up that go to a small connector which on the other side of the connector is just a black and the white with the orange/brownish line. you can tap on either side of the connector and it will work just fine. black ground, white or white with stripe is parking power. There is less slack to work with than in any of the videos I've seen even after popping off the zip tie that clips the wires in that area, so its tight quarters. otherwise it was pretty easy. the 22 gauge wires are really really thin, so it is a little tedious clasping up the taps, but just take your time and make sure its lined up before using plier to bite down.
Hope this helps!
