New update for 8.4 Uconnect radio
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Their site says the full version is required for Configuration changes. These are the two settings that need set to yes:
Cust.Set.Menu 3: Tire Fill Alert Enable/Disable CSM Present: Yes
VehConfig 8: Selectable Tire Fill Alert Present: Yes
You also need a Security Gateway Bypass cable and an OBD dongle as usual.
By dongle you mean an OBD to USB cable to the laptop?
ALRUI
Arnold
Murphy, NC
quality improvements, wondering what that meansšŸ¤”
It's a cop out. When a version changes version history should be available. You see this on a lot of phone apps also. Having version history is helpful if you need to diagnose issues!
Sanchese
Carlos
Toronto, Canada
2021Rubicon, 2022 Rubicon Xtreme Recon on Order
I have an 8.4 uconnect.
I guess I have been lucky since I have had no issues or problems.
Android auto has worked flawlessly with my Samsung S20.
LG1907
Linda
Mendon Massachusetts
2019 Jeep Rubicon
When I pulled into work today, my 8.4 radio said it wanted to install an update. I guess we'll see what happens later on today when I go home.
Has anyone else gotten an update recently?
I figured they were done with Uconnect4 units and moved on with Uconnect5.. I didn't expect any more updates.
Does it update for free? I got a link to pay $149 to update mineā€¦ i live in Massachusetts and theyā€™re changing the highway exit numbers to distance
Obi Wan
Obi
Tatooine, Outer Rim
starwars.fandom.com
2023 JLU SPORT S 2.0, 2004 TJ SPORT 5.3LS
Jedi Knight
Jeep Wrangler JL New update for 8.4  Uconnect radio 1674581656178
Bryce
Bryce
Bryce
Acworth, GA
2019 JLUR
the $149 is for the Nav map update. This is update is for the system software.
2mnycars
Canada
JLUR
Hold the drivers side temp increase, temp decrease, and front defrost buttons down at the same time for 5 or 6 seconds. That should get you into ā€œdealer modeā€. From there, youā€™ll find it.
Thanks!
Much appreciated.
DaveL
Ratbert
COS region, CO
AEV JL370 JLURD , AMG GLC43
Software Engineer
Another reason to not use the crappy built-in navigation unless there's no other option.
IAJeepguy
Nick
Iowa
2021 JLUR EcoDiesel
ACMX
I have a ā€˜21 Rubicon with the 8.4 and no updates to my knowledge unless it updated itself in the background. Iā€™d have to do some playing around with things to verify. Only issue Iā€™ve had with my system is the way button icons haphazardly relocate themselves on the pages.
@rcadden you shouldnā€™t have an issue with getting the selectable tire fill alert as my Jeep has it. As someone else mentioned I think itā€™s more of a PIA than anything. Maybe I just donā€™t understand how itā€™s supposed to work. šŸ˜†
IAJeepguy
Nick
Iowa
2021 JLUR EcoDiesel
ACMX
For those that keep stating the update is for the emergency vehicles alert. I donā€™t believe thatā€™s correct. Iā€™ve been getting that for over a year.
rcadden
Ricky
Fort Worth, TX
Marketing
Weird - I tried to activate it a few times last night with JScan and couldn't get it to show up at all. Finally gave up and figured mine wasn't equipped, but if you have it, then I should have it, for sure.
Wonder if it's Rubicon vs Sahara though?
IAJeepguy
Nick
Iowa
2021 JLUR EcoDiesel
ACMX
Well, I guess I didnā€™t put into consideration that you are in a Sahara. That may be the link. I assumed it was available on any trim level. šŸ¤”
rcadden
Ricky
Fort Worth, TX
Marketing
It's also entirely possible that I wasn't using JScan correctly, lol. I might give it another go.
