FourthJeep
- Jason
- Sep 30, 2018
- Longmont, CO
- 2018 JL Rubucon
I had been debating for months what tires to pick to replace my OEM BFG's on my Rubicon. I wanted to go larger, but wasn't ready to do a lift yet, and as a daily driver wanted to stick to a lighter weight tire and avoid any rubbing that might occur off-road. After a ton of deliberation, I had narrowed down my options to the Nitto Ridge Grappler in load C or the Falken Wildpeak in load E as these were all available in a 285 75 R17 size. This should provide an extra inch of tire and half inch of ground clearance over the KO2s.
I was excited to see last week that Toyo had released their Open Country's in a new version, the AT3 and that it came in this size and with a C load rating. The dimensions are effectively the same as the Nitto's, but with a tire weight of 59lbs instead of 65lbs. They were also less expensive so this made the choice a lot easier. I got a set of five tires with mount/balance/disposal/alignment for $268/tire when it was all said and done from the dealership with their buy 3/get 1 sale.
It's too early to say about driving impressions, but overall I'm pleased. When I first saw my Jeep I thought the tires actually looked smaller until I pulled up next to a brand new rubicon and compared. The tires are clearly larger side-by-side and I measured the height to be a true 33", almost 1.5" more than the KOs (which had 30k on them). While they are both 285 in width, the manufacturer stats show 285/75s to be more narrow than 285/70s. I tried to measure the width of the tire lugs and found them to be near as makes no difference about 9" If anything, the Open Country's are wider than the KOs that I had replaced.
I'm liking the look of the OC AT3s, they have larger voids and feel a little more aggressive with the tread, though not as much in the sidewall. The sidewalls are ever so slightly different on each side and I chose to have the more 'aggressive' sidewall facing out, but it's barely noticeable. You can tell the difference because the sidewall 'lugs' have a minor sipe in them. I think these will work quite nicely until the next replacement when I will go larger.
