gridsquares
I have a new-in-box set of Synergy Mfg. JL rear sway bar links. I ended up using the ones that came with my RK lift. Asking $110 (Northridge4x4's price).
Synergy Jeep JL Rear Sway Bar Links are adjustable and longer than stock, allowing full articulation on lifted vehicles. Compatible with stock wheels when used with Synergy 8886-02 Rear Sway Bar Drop Brackets.
Benefits:
Benefits:
- Allows full articulation of rear suspension on lifted vehicles
- Adjustable for optimum sway bar angle
- Sway Bar Links are made from 11/16 inch solid 1018 steel and are clear zinc plated and powder coated for maximum corrosion resistance
- High-quality rod end reduces bushing deflection causing the swaybar to operate more efficiently
- 100 percent bolt-on components assures an easy, trouble-free installation with the use of basic hand tools
- Uses stock mounting hardware
- Compatible with lifts 2-inch and up (2-6in lift)
- Compatible with stock wheels when used with Synergy 8886-02 Rear Sway Bar Drop Brackets.
