NEW! Stage Series LED Rock Lights by Diode Dynamics
Diode Dynamics
Summit Sponsor (Level 3)
St. Louis, Missouri
www.diodedynamics.com
2018 Jeep Wrangler
Jeep Wrangler JL NEW! Stage Series LED Rock Lights by Diode Dynamics {filename}
Our team here at Diode Dynamics is excited to introduce our highly anticipated Stage Series Single Color and RBGW LED Rock Lights!
With high-power LED emitters, these USA-assembled units are a major step up from any other rock light on the market today. Rock lights are a perfect solution to add light underneath your vehicle on the trail. Or, with their compact size and numerous mounting solutions, you can add these anywhere you need some extra light - your cargo area, under the hood, on a roof rack, the side of a trailer, and more. The applications are endless!
Single Color Rock Lights. With a true power draw of over 10 watts, the Stage Series Rock Light provides a peak output of 1000 lumens. Even with claims of high power, generic rock lights run at only a few watts, making the Diode Dynamics Rock Light a huge step up for the entire category. Where generic rock lights require two or three units to light up one space on the vehicle, you’ll only need one to get the coverage and output you need.
Dual Power Levels. The Stage Series Rock Light uses a simple 3-wire system, allowing you to select a low-power or high-power mode. At 3 watts of output, the low-power mode is actually on-par with the max output of most generic rock lights! If you want to light up a campsite and you don’t need all 1000 lumens, the low-power mode is a great way to conserve battery power. This 3-wire setup also provides much more functionality on custom off-road builds. By tying the low and high power wires into your factory harness, you can use them as a dual-function running/brake light, or running/turn signal, all in one simple package.
Available Packs: Single, Dual, 4-Pack, or 8-Pack
Choose Your Color. Stage Series LED Rock Lights are available in cool white, amber, red, green, and blue. With the same high-power white LEDs underneath, the interchangeable lenses allow you to change colors any time. White is a great option to get the maximum output possible. Green and blue provide serious style. And red or amber colors could become very functional options on an off-road setup, by powering the low and high power inputs with your running light and turn signal, for example.
Optically-Engineered, Interchangeable Lenses. Most rock lights are built without optics in mind. They use a simple clear cover to protect from the elements. In true Diode Dynamics style, we’ve incorporated optical features to get the best performance possible. Four individual optics are molded into the outer lens, which provides excellent spread and even, consistent coverage from each light. The lens itself is a thick automotive-grade polycarbonate, made to take a beating on the trail. And the best part? The lenses are interchangeable and can be swapped out easily as needed.
Bluetooth Compatible with the Diode Dynamics App for Apple/Andriod
RGBW Rock Lights. With four high-intensity RGBW LED emitters, the Diode Dynamics Rock Light provides plenty of output in any color you can think of, paired with our RGBW remote or RGBW Bluetooth controller and app. The diffused optical feature of the lens provides excellent integration of colors. And unlike other multicolor lights, the extra white chip means that these will light up in a bright, pure white color when you want to maximize output. Want to show off? Use your controller to start a pattern, strobe, fade, or control the brightness. The best of both worlds!
Mount it Anywhere! These Rock Lights were designed to be mounted virtually anywhere on your vehicle. All rock lights come standard with a center bolt mounting point, which is neatly hidden underneath the lens. The aluminum heatsink also features hidden mounting tabs for quick zip-tie installation, if preferred.
If that’s not enough, we also offer a variety of mounting solutions, including a roll bar mount, magnetic mount, flush mount, and surface mount to cover any other potential application.
Surface Mount Displayed
Flush Mount Displayed
Roll Bar Mount Displayed
Magnetic Mount Displayed
Each of these accessory mounts is designed to mate up perfectly with the base rock light unit, for a professional and clean appearance when installed.
Simple Connections. For maximum convenience, these are available with either 10-inch bare wire leads, or an M8 barrel-style connector. The bare leads are a great option if you plan to wire them up yourself, while the M8 option provides a secure, waterproof connection and is compatible with our plug-and-play harnesses. At only 8mm in diameter, it’s still easy to route the wires to where you need them.
Proven Reliability. We know your rock lights will be put to the test, so you can rest assured that they have been designed for superior durability. They are IP68 waterproof rated and feature a cast aluminum housing and pin-fin heatsink, for effective thermal dissipation. The lens is designed with thick automotive-grade polycarbonate, and a UV coating. Backed by a limited 8-year warranty, they have been tested in-house from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. Rest assured, the Stage Series Rock Lights will handle whatever you throw at them.
If you have any questions, we'll be more than happy to help!
Monday-Friday 10 a.m.- 5 p.m. CST
Email: contact@diodedynamics
Phone: 314-205-3033
Did you know? All US forum members are eligible for a FREE SHIPPING code! Just send us a direct message.
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Our Black Friday Sale is LIVE! 🚨 Visit the website for our BIGGEST savings ever!​
➡ 20% OFF Sitewide
➡ 30% OFF Stage Series Single-Row Lightbars
➡ 15% OFF Elite Series Headlights
➡ Free US Shipping on any order with a HitchMount LED Pod, or orders over $300.
No coupon code is required.
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.​
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Our BIGGEST and LAST sale of the year ends TODAY 11/29 at 11:59 pm CST!
➡ 20% OFF Sitewide
➡ Plus, orders over $300 receive free US shipping!
Excluded Products:
➡ Hitch Mount LED Pods (Includes free US shipping)
CLICK HERE TO SHOP!
John C.
Diode Dynamics
Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Did you know?
We’ve incorporated optical features to get the best performance possible. Four individual optics are molded into the outer lens, which provides excellent spread and even, consistent coverage from each rock light!
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
In this video, we show you how easy it is to swap the lens on your Stage Series Rock Lights! With 1000 lumens of peak output, these USA-assembled units set a new standard in the rock light category for brightness. LED rock lights are a perfect solution to add light underneath your truck when you go off-road. Or, with their compact size and the numerous mounting solutions you see below, these can be added anywhere you need some extra light - your cargo area, under the hood, on a roof rack, the side of a trailer, and more.
The applications are endless! Stage Series LED Rock Lights are available in cool white, amber, red, green, and blue. With the same high-power white LEDs underneath, the interchangeable lenses allow you to change colors any time. White is a great option to get the maximum output possible. Green and blue provide serious style. And red or amber colors could become very functional options on an off-road setup, by powering the low and high power inputs with your running light and turn signal, for example.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Our Spring Sale is LIVE! 🚨 Visit our website to SAVE!
➡ Up to 15% OFF All Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
➡ 10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
Click HERE to shop your ride!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 3/13/2023. Cannot be combined with other coupon codes. Excludes items with pre-order status.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Added an in-stock JL HitchMount C1R to my cart and the 15% discount isn't automatically applied.
Ugh. Was showing 42 in-stock when I posted, now showing "backordered" so not eligible. This happened during the last sale. Advertising a discount that can't be honored 🤬
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Not sure when the issue occurred, we haven't had any reports but will keep an eye on the site!
HitchMount C1 and C1R configurations are live and discounted.
  • Like
Reactions: AFD
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
⌛THE CLOCK IS TICKING... ⌛
NOW
is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
➡ Up to 15% OFF LED Lighting Upgrades
CLICK HERE TO SHOP NOW
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
This video explains how to mount the numerous mounting options available for the Stage Series Rock Lights! These Rock Lights were designed to be mounted virtually anywhere on your vehicle. All rock lights come standard with a center bolt mounting point, which is neatly hidden underneath the lens. The aluminum heatsink also features hidden mounting tabs for quick zip-tie installation, if preferred.
If that’s not enough, we also offer a variety of mounting solutions, including a roll bar mount, magnetic mount, flush mount, and surface mount to cover any other potential application. Each of these accessory mounts is designed to mate up perfectly with the base rock light unit, for a professional and clean appearance when installed.
Click HERE to check out Stage Series Rock Lights + Mounting Accessories!
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
We've just installed new machinery to ramp up production speed and meet the growing demand for our Stage Series Rock Lights.
A big thanks to our loyal customers for their patience, and to those who haven't ordered yet - they'll be in stock soon!
Click HERE to learn more!
