NEW! SS3 LED Pods for JL Wranglers! | Diode Dynamics
Diode Dynamics
Summit Sponsor (Level 3)
St. Louis, Missouri
www.diodedynamics.com
2018 Jeep Wrangler
Jeep Wrangler JL NEW! SS3 LED Pods for JL Wranglers! | Diode Dynamics fGUwy5
Diode Dynamics is pleased to offer our new USA-made SS3 LED Pods!
Introducing Diode Dynamics new SS3 LED Fog Light Kits for the 2018+ Jeep JL Wrangler! Compatible with both the plastic and steel bumpers, our SS3 Fog Light Kits allow you to mount two of our 3" SS3 LED Pods in your factory fog light location. Our LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
Jeep Wrangler JL NEW! SS3 LED Pods for JL Wranglers! | Diode Dynamics SS3_Type_M_&_Type_MR_Bumper_Comparison_Graphic
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered TIR optic in the SS3 collects all of the light from the LED, drastically reducing wasted light and improving total efficiency.
Jeep Wrangler JL NEW! SS3 LED Pods for JL Wranglers! | Diode Dynamics 6G5v0WW
While these outdated optics lose up to 10% of the light output shining through an outer lens, the SS3’s custom-molded TIR optic functions as both the optic and the main lens, dramatically increasing the amount of usable light output.
Functional Patterns: All SS3 LED Pod beam pattern options were designed with optical simulation modeling, to shape the light output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is an SS3 LED Pod for you!
  • Our SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
  • Our SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
  • The Flood optic was engineered to provide uniform, even illumination with a full 60x60 degree spread of light. Unlike typical "flood" lights that are just a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout. It’s the perfect optic for use as a backup light, lighting up tight trails at low speeds, or for loading trailers and setting up worksites.
  • Finally, our Spot optic is an unmodified pattern, shining light directly from the TIR optic. The result is an extremely focused 6-degree beam of light, perfect for directing light far into the distance. With an incredible output of 151,000 candela, the SS3 Sport shines a half-mile away (¼ lux), from a compact 3-inch package!
Jeep Wrangler JL NEW! SS3 LED Pods for JL Wranglers! | Diode Dynamics OIrk1e
Not just off-road! When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use*.
*Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow: Our SS3 LED Pods are available in your choice of 6000K cool white or 3000K selective yellow. The white is a 6000K color temperature, which is a true white output, without any blue, and is a perfect match for most OEM LED lights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a totally unique look on the road.
Jeep Wrangler JL NEW! SS3 LED Pods for JL Wranglers! | Diode Dynamics e4jYmb3
Sport or Pro: Stage Series LED Pods are available at two different power levels. Both the Sport and Pro options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power!
Simple Installation:
All SS3 LED Pods feature a custom-molded DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire the SS3 yourself, use an off-the-shelf Deutsch DT sized wire harness, or select an optional Diode Dynamics wire harness. Our Light Duty Dual Output Harness can be used to power up to two SS3 LED Pods. If you are looking to install more than two SS3 pods, we recommend using our Heavy Duty Dual Output Harness along with a Deutsch DT Splitter.
Jeep Wrangler JL NEW! SS3 LED Pods for JL Wranglers! | Diode Dynamics Jeep_SS3_Forum_M_&_MR-Graphic
Proven Reliability: Our SS3 LED Pods have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like OEM components!
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
https://www.diodedynamics.com/off-r....html?utm_source=JLwrangler&utm_medium=forums
Jeep Wrangler JL NEW! SS3 LED Pods for JL Wranglers! | Diode Dynamics Jeep_SS3_Forum_Plastic_VS_Steel_Bumper - Graphic
JoshuaaT
2018 JLU 6 Speed
Will the kit work with the JL sport stock bumper?
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Check out this awesome shot of our SS3 Pro Fog Light Kit on a 2019 Jeep Rubicon. Love that 3000K selective yellow! Installation and picture courtesy of The RetroShop LLC!
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Our Memorial Day sale starts NOW! Today through Friday, 6/4/2021, save 15% on all LED upgrades, including our SS3 LED Fog Light Kits by entering coupon code "USA15" at checkout!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 6/4/2021. Cannot be combined with other coupon codes.
Taxman
Alex
Raleigh, NC
1985 CJ-7, 2018 JLUR
CPA
Just installed a set of SS3 Pros in yellow in my Motobilt bumper. Used the same hardware as for the stock plastic Rubicon bumper. The fit was absolutely perfect and the quality of the parts is excellent. Everything feels beefy and solid. Connections were a breeze with the included pig tails that connect directly to the OEM harness. There’s about 2-3 degrees of adjustability that allows for fine tuning the spread of the light if you have a lift and need to lower the beam slightly. The color is a perfect yellow to cut through thick fog and reduce the blinding effect of white lights. They are about 3-4 times visibly brighter than the stock LED fog lights that come with the Rubicon. Overall very pleased. Going wheeling next week and will have an opportunity to submerge them. I’ll report if there are any issues, but based on how solid they’re built I doubt I’ll have any.
jludave
The Isle of Long
IT Manager
I concur with the poster above, except my lights are the SS3 Sports in amber installed in my stock Sport Altitude bumper. They are super bright and the fit and finish are extremely high quality.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
We're glad to hear that you're both loving your lights! Thank you @Taxman and @jludave for your positive feedback!
Our team appreciates your support here at Diode Dynamics. 😎
If you ever have any questions, I'll be glad to help!
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
@Diode Dynamics
Are you guys planning on running any specials for 4th of July?
Yes, we will be offering 15% off all products and releasing our NEW Stage Series LED pod the C1!
This sale will begin June 30th and end on July 7th at midnight CST.
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Our July 4th Sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our newly released SSC1 LED Pod, by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive a free Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 7/8/2021, you can use coupon code "JULY4" at checkout for 15% off your entire order of lighting upgrades, including our newly released SSC1 LED Pod! Don't wait, this sale ends TONIGHT!
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
In this video above, we compare our SS3 LED Fog Light Pods to other market-leading fog lamps! We break down each fog lamp by intensity, beam pattern, color temperature, and price.
For this comparison, we've used our state-of-the-art Goniophotometer, a device that measures multiple points to calculate the intensity and map out the beam pattern of each fog lamp! We've also used our integrating sphere, which is a device that is used to measure the color temperature of each fog lamp. We hope the data we collected helps you choose the best fog lamp for your vehicle.
John C.
Diode Dynamics
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Check out this awesome video submitted featuring our SS3 Sport Fog Light Kit in 6000K cool white!
This video features stock reflector headlights with an LED upgrade bulb to begin. Then our SS3 Sport LED Fog Light Kit is turned on to display the improvement from our SAE-compliant beam pattern.
Remember, all forum members are eligible for a free US shipping code. Just PM us!
John C.
Diode Dynamics
TrailSnail
Josh
Gilbert, AZ
'21 JL Unlimited Sport S
@Diode Dynamics I'm installing an aftermarket steel bumper to replace a plastic Sport bumper - am I correct in assuming that it doesn't matter which kit I select because the bumper itself comes with adapters for the OEM fog lights, and/or would it be possible to order just the amber SS3 fog pattern "Max" lights without adapters?
