NEW: Smoked Sidemarkers for Jeep Wrangler JL/JT
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
ORACLE Part# 5853-504
Enhance the look of your Jeep Wrangler JL or Gladiator JT with these dark tinted lens LED Sidemarkers from ORACLE Lighting. Featuring bright amber LEDs these markers retain reflective properties and illuminate at night. Wiring is easy “Plug and Play” connection to the factory socket without causing any errors.
Direct fit and matched to factory design for OE-quality fitment so these replacement LED sidemarkers drop right into place of the factory sidemarker housing. These sidemarkers are compatible with all JL and JT models, whether you have standard halogen or LED light package. Best of all, there is no modification required for installation.
Lens Material: PMMA
LED Color: Amber 615nm
Warranty Period: 1 Year
Check out more information HERE!
Installation Video:
ORACLElights
ORACLElights
Metairie, LA
Here's how they look un-illuminated and installed on this Jeep!
ToPar9
North Texas
'19 JLU Altitude
Hello @ORACLElights.
I watched the install video you posted. (Thank you)
How critical is popping the first rivet off of the fender? Can a flex shaft work its way to the T25? I am sure getting the bolt started after removal would be a PITA.
I want to install the side markers ASAP, but I don't have rivets readily available. :like:
ORACLElights
ORACLElights
Metairie, LA
We were not able to do it that way but it depends on the flex shaft you are using and your dexterity. It is worth a try!
Fire Burns
Fire
CA
2018 JLUR 3.6; 2006 Chrysler 300c SRT-8
You guys have a clear version?
ORACLElights
ORACLElights
Metairie, LA
ORACLElights
ORACLElights
Metairie, LA
This closeup tho :muscle:
ORACLElights
ORACLElights
Metairie, LA
