New Shoes, but does the spare really fit?
Teflon4xe
Tom
Roseville
2022 Rubicon 4XE
Just got the wife a 2022 Rubicon 4xe.
Having Metal Cloak 3.5" lift installed Monday.
Keeping stock wheels and mounting 37" BFG KO2s. C Load.
I thought I saw in another forum that I can use the stock spare tire carrier, and the light is adjustable... And if I lower PSI to like 15psi the tire will just fit
Can anyone tell me if this is true, and if so, what steps I might have
Thanks
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
One thing to consider as well is your wheel dimensions (offset/backspacing) with your stock carrier. I have 35’s with more aggressive -19mm 10” wide wheels and it brought the tire out from the rubber tire stop. Everytime I shut the tailgate or went over bumps the whole thing would shake violently. After upgrading to an aftermarket fully adjustable carrier (I think Teraflex) it no longer shakes and is solid against the oem rubber tire stop.
Additionally, the new carrier relocates the brake light in the center of the wheel so it’s way easier for people to see the light.
Rhinozeroone
Northern VA
2018 JLUR 2.0
I was able to use the stock carrier with a 37" tire on a 4.5" backspace wheel. The tires we had were about 1/2" taller than the K02s with actual measurements. I was able to adjust the brake light so it was just peeking over the tire. The K02s should be a little better for this.
Terpsmandan
Penn Yan
That's about 108 pounds. That will not work. The stock carrier tailgate is rated to 85 pounds. Do you have the factory tailgate reinforcement? If so you can add this:
https://teraflex.com/jl-alpha-hd-ad...ount-kit-w-brake-light-camera-mounts-5x5.html
It is good to 100 pounds without tailgate reinforcement. I have the tailgate reinforcement from the factory and added this to get my 37" KO2 on the back. It is adjustable fore and aft so I have the tire tucked in closer to the tailgate than my wife's 35 on the stock carrier with factory reinforcement.
Jeep Wrangler JL New Shoes, but does the spare really fit? spacers
Jeep Wrangler JL New Shoes, but does the spare really fit? carrier
Teflon4xe
Teflon4xe
Tom
Roseville
2022 Rubicon 4XE
The 37" tire weighs 12.7lbs more on the stock rims.
I ordered a relocation bracket for now, looks like I might need the reinforced hinge
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
I’ve been running 37s on my stock carrier for several years. It’s fine. I haven’t heard anyone with issues. Hell I’m running 37s on my sport tire carrier as we speak with no relocation brackets. As long as you have the plastic bumper you won’t need the relocation bracket.
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Is that a retro Jeep badge back there?
Terpsmandan
Penn Yan
Teflon4xe
Teflon4xe
Tom
Roseville
2022 Rubicon 4XE
That's what I read, I knew I wasn't crazy. Did you go the tailgate reinforcement?
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Wife's), Tesla M3P (mine)
I'm running a 37" KM3 on the OEM spare tire mount on my wife's JLUR, with the Mopar tailgate reinforcement. I've got a Motobilt tire carrier on the way and will be selling the Mopar one once the new one gets here.
OnlyOne
That's what I read, I knew in wasn't crazy. Did you go the tailgate reinforcement?
No. Nothing. With the C KO2 it’s not even close to needed.
NebulaPHEVJeep
Nebula
Kansas City
2022 Jeep Wrangler JLUR 4xe
Thanks
Get the reinforced tire carrier. You will thank yourself later. But yes, our light is adjustable and it will fit.
