New! Quick disconnects for the JL
RanchoShocks
Peak Sponsor (Level 2)
CA
www.gorancho.com
2013 JKU
Rancho®’s Adjustable Front JL Quick Disconnect Sway Bar End Links quickly detach at the lower mount to instantly improved off-road performance. Quickly disconnect the lower Sway Bar End Link and swing it up out of the way for unhindered axle articulation while off-roading. Pivot around the OEM inspired ball and socket upper mount to the powder coated sway bar relocation brackets,
tucking them safely out of the way.
Precisely adjust the massive 3/4-in. diameter DOM link tube while it’s still installed on the vehicle. Forged lower ends feature Rancho’s D2 Synthetic high-articulation bushings that are maintenance free. 3/8-in. thick HSLA steel axle mounted relocation brackets reduce any chance of interference with aftermarket track bar brackets. When connected for street use, the link provides immediate reaction during sway bar loading to eliminate excess play. This results in improved lateral control and steering response compared to the stock rubber sway bar link bushings.
TL/DR
Our disconnects allow for flex off-road and maintain a nice on-road feel when connected driving around.
Check with your retailer on cost.
DatsunX3
Dale
Arizona
2020 2dr Sport S - Ordered
@RanchoShocks
Are these QD sway bar kits available yet?
Will they work with a stock Sport w/o a lift?
Do you have any videos for installing or using them?
RanchoShocks
RanchoShocks
CA
www.gorancho.com
2013 JKU
See below in BOLD :)
@RanchoShocks
Are these QD sway bar kits available yet? Yes we have them and are selling them now!
Will they work with a stock Sport w/o a lift? Needs a minimum of 2" system
No video but will attach install instructions to show how easy they are to install.
DatsunX3
Dale
Arizona
@RanchoShocks ,
Thanks so much for the quick reply! Your system looks nice. I like the relocation bracket on the lower end, so no cutting.
I wasn't planning on doing a lift so it may not work out for me. However, I will consider them if I decide to do a small lift.
Thanks again!!
Dale
MrMora
Joseph
Riverside
2019 Jeep Wrangler JLU
Carpenter
Thanks for posting this just picked up the rubicon express set but didn’t realize I had to do some cutting I’m taking them back and getting this the set up is also all around better
danelizer
Dane
FL, USA
2021 Gladiator Rubicon
Business Manager
I heard through another thread that these links are too long for the JL’ s with 2” lifts. Fact or fiction? I have a set on back order. I have the Mopar 2” lift installed.
RanchoShocks
RanchoShocks
CA
www.gorancho.com
2013 JKU
Fiction, since that lift nets more than 2" they will work no problem.
:beer:
danelizer
Dane
FL, USA
Business Manager
:beer:
Thank you. I appreciate the quick response. I’m looking forward to getting them installed.
danelizer
Dane
FL, USA
Business Manager
When will these be shipping again? I ordered from Summit in March and they still show back order.
danelizer
Dane
FL, USA
Business Manager
You guys still making these? If not I’ll move on.
RanchoShocks
RanchoShocks
CA
www.gorancho.com
2013 JKU
100 more are being packed today and shipped out on Monday!
danelizer
Dane
FL, USA
Business Manager
Finally!!! Mine are due in tomorrow.
Motor City Aftermarket
