- Feb 27, 2017
- United States
- Jeeps
(Aluminum bumper non-tire carrier will available to ship 1st week of December)
Bumper Only: https://www.rockhard4x4.com/product_p/rh-90300.htm
NOW AVAILABLE! LEARN MORE: https://www.rockhard4x4.com/product_p/rh-90301.htm
Fits all 2018 - Current Jeep Wrangler JL models.
INSRUCTIONS: https://www.dropbox.com/s/ciqc4hn1i1anng2/RH-90301.pdf?dl=0
We believe armor should be stronger than the vehicle. We believe upgrades should be heavy duty, premium, and easy to install. If you do too, the ultimate rear bumper with tire carrier for the Wrangler JL is here!
Fully loaded and incredibly strong, the Patriot Series Rear Bumper with Tire Carrier RH-90301 retains every single factory option moved to a 1/4" thick steel armor upgrade. Frame mounted takes the weight off your JL's body giving you the option to add accessories plus extends the life of your tailgate.
100% bolt-on installation makes removing your factory bumper and upgrading to a Patriot Series rear bumper doable by any level installer.
FEATURES
SPECIFICATIONS
Weight: 150 lbs.
40" tire rated (38" with cargo basket/tank mounts)
Width: 70"
OPTIONS
Longer off road excursions require more cargo and fuel. Our design is the perfect platform for accessories. Our optional heavy duty driver and passenger side Tank Mounts and Cargo Rack bolt on to our tire carrier to give you space you need for extended range or duration trips.
Components
Reverse camera compatible.
License plate mount included with light provision.
Parking/reverse sensor compatible.
OEM 3rd brake light mount included.
High clearance design to maximize departure angle.
Bolt on tailgate streamer bar helps apply preload to closed tire carrier gate preventing vibrating and wobbling. A Rock Hard 4x4 exclusive feature.
Adjustable design allows you to move your spare tire up and down or in and out for best fitment and visibility.
Included laser cutout for rear receiver wiring. Block off plate included.
Drop down safety pin automatically prevents tire carrier closure when open on uneven ground.
Integrated welded on CB antenna mounts standard on every tire carrier.
Integrated Hi-Lift jack mount standard on every tire carrier.
Welded on security tab allows you to use a cable style lock to prevent Hi-Lift jack theft.
Zerk style grease fitting to service hub assembly.
FEATURES
- 1/4" thick plate steel
- 100% bolt-on design
- Frame mounted bumper/tire carrier (zero weight on tailgate/body)
- Adjustable spare tire mount
- Back-up camera compatible
- Parking sensor compatible (grommets included)
- Plastic plugs included if not sensor equipped
- Integrated 2" tow-rated receiver
- Hi-Lift jack mount included (with security cable tab)
- CB antenna mount included
- 3rd brake light compatible
- Integrated safety chain attachments
- High clearance tapered sides
- Towing electronics port provision (block off plate included)
- 1" thick double welded recovery tabs included
- Powder coat included
- All hardware included
SPECIFICATIONS
Weight: 150 lbs.
Width: 70"
OPTIONS
Components
