I have a 2012 white Jk and have had no problems with the grill , nor have I ever seen such a problem.I will be doing the same as the white turns a weird non white color
Yes that’s it. Liked it all blackLook good!
That's the Mopar Grill Assembly, right? I base this on the white grill in your Wife's hand still has the 3 moldings on it.
I posted info.. part #'s, below, for both grills, for those that may be interested in going black.
Mopar Grill Assembly:
The Mopar Satin Black Grill offering.. Runs $300+ :
Looks great, nice job!Installed my New Mopar Grille today. Easiest install ever!
Looks great!Yes that’s it. Liked it all black
6 pop up out clips with a screw driver. That took about a minute and a half then it was just pulling out from the bottom to undo clips. Then line up new one push at bottom slowly across and then pop back in the pop out clips and your set DONE! You know they say it’s always easy but trust me this was easy! You can do it. See “you tube” installing grille on JL. Super easyLooks great!
So how easy was it to install?
The JL white grills are yellowing apparently due to heat. Very well documented on the forum.I have a 2012 white Jk and have had no problems with the grill , nor have I ever seen such a problem.
Thanks for the heads up. I am waiting on the Scrambler release and only dab around here a little. If the Scrambler does not fit my needs I will be ordering a white Jl 2 door. Sounds like the yellowing of the grills is showing up well within warranty. I'll worry about it then.The JL white grills are yellowing apparently due to heat. Very well documented on the forum.
https://www.jlwranglerforums.com/forum/threads/bright-white-grille-turning-yellow.6394/
Looks great! I have thought about doing something like this for some time now. Just haven't pulled the trigger yet.Installed my New Mopar Grille today. Easiest install ever!
