New lift, funky symptoms. Need advice. UPDATE
JT1
Broken Arrow, OK
2021 Willys Gladiator
Hey all. 2021 Gladiator (I know, but you guys are way more active). Installed a Clayton 3.5", fox 2.0s and 37" Patagonia's.
I confirmed I'm at 6* caster, and both axles are centered. On the highway it drives pretty well, but it has next to no steering resistance driving straight. On cambered roads it wants to turn downhill pretty hard. Initially it crashed over broken pavement. Lowered the tires to 34# and that has calmed that issue pretty well.
So, what can I do to firm up the dead ahead steering, and keep it from trying to dive out of it's lane?
Will the steering module reset change anything? Will an adjustable damper/stabilizer help?
Roky
Roky
Central Florida
The fox ats stabilizer will firm up the steering, but be careful on adjusting it. If you make it to firm it will counter act the caster and cause a shimmy. I just advanced mine until the steering wheel shimmied then backed it off a couple clicks. Mine landed on 17 clicks with 6.2 and 6.4 degrees caster. Also with 37s , I’d take your pressure down to 30 warm, this also will help.
JT1
Broken Arrow, OK
Which version of the through shaft did you get?
Running the pats that low wears them out.. at 34, I'm pretty happy with the ride and they chalk test like they should.
Roky
Roky
Central Florida
Yeah, they’re pats, they’re gonna wear out quick regardless, very soft tire, lol.
JT1
Broken Arrow, OK
True, they definitely do. If I can get 35k out of them, it will at least allow me to pay the jeep off before I need to replace them. Plus they are a pretty narrow carcass, so I'm not too worried about running them on the stock wheels.
JimLee
Jim
Too damn close to Death Valley
'19 JLU
Which version will depend on your steering setup, they make one that bolts to the stock JL steering, but most people running aftermarket steering use the JK version with a bolt that replaces the track bar bolt and allows you to mount SS there.
JT1
Broken Arrow, OK
Does the JK version also clamp to the tie rod?
JimLee
Jim
'19 JLU
Yes, it's the axle side that varies depending on your config, you also gotta watch for differences in tie rod diameter with the aftermarket tie rods as that will effect the clamp side.
JT1
Broken Arrow, OK
Are there advantages to one or the other? Price, performance, adjustability?
JT1
Broken Arrow, OK
In reference to the steering stabilizer or the aftermarket steering components?
Any advantages to converting to the JK style stabilizer? Hoping that this actually helps the steering..
Roky
Roky
Central Florida
The JK version is 1.5” clamp, that’s what I’m using because my synergy tie rod is 1.5”. The JL tie rod is 1-5/8” so if you plan on upgrading your tie rod make sure it’s the right diameter to fit the stabilizer you get.
JimLee
Jim
'19 JLU
I love it myself, it lets you dial in the steering firmness you prefer and greatly reduces bump steer. Using the Fox ATS JK version gets the stabilizer higher and more protected than the factory location, I just don't thing it will mount correctly with the factory tie rod (IIRC, haven't seen the stock setup in a couple of years).
  • Like
Reactions: JT1
Some Random Guy
Washington
2020 JLUR, 2018 Subaru BRZ
Comptroller
Could you have accidentally achieved zero scrub radius?
“Most vehicles will not be designed with zero scrub radius, but changes in ride height and wheel offset can unintentionally create a zero scrub radius. When scrub radius is zero, tension on the steering system is reduced and vehicle handling will tend to be unstable. Zero scrub radius also causes the tires to scrub in the opposite direction of rotation during turns (tire squirm). This has a negative effect on handling in turns and affects overall tire wear.”
Source
PSC Motorsports
