IronScott
NW Arkansas
2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
This one came loose easier than my old aluminum box. Never had to use heat on this one b
Cool. Definitely be interesting to see how it works if you install it. Thanks for posting your experience.
B-man
Brett
Rubicon
This is probably a dumb question but how do I private message Jeep Cares?
I canā€™t find a how-to page and nothing seems intuitive to tee this up.
Thanks
2mnycars
Canada
JLUR
2mnycars
Canada
JLUR
Just picked up my Jeep from the dealer this morning. Part number installed was listed on service paperwork as 68507569AB instead of AA which is listed on the latest TSB. Sticker on the actual steering gear confirmed AB
I'm confused!
on TSB 08-003-21 the part number for a JL our door left hand drive (NOT diesel) is 68507574AA
That's a new number as you've figured out.
MAYBE that will help me. My JLU has the number on the TSB and has a dead spot on centre.
Jeep&dogs
Cedar Lake
2020 JLUr
I'm confused!
There is apparently been a revision on the box and it has a new part number now.
2mnycars
Canada
JLUR
I printed off 08-003-21 a few days ago...
2mnycars
Canada
JLUR
Thanks....frankly I don't know what to think. I've searched for a fix for 1-1/2 years.
When will they get it right.
I adjusted my first steering box in about 1972. Darn things have been around a long long time.
2mnycars
Canada
JLUR
I wonder if it's specifically for the Rubi JLU?
californiajeeping
JLUR
no sir. Pull is the same in every street (yes I thought it could be the highway deeper road tracks)
Side streets, parking lots, slow, fast, doesnā€™t matter.... pulls to the right and requires a constant wheel pressure ti the left so it tracks straight.
Did you remove the steering stabilizer and tested it yet?
JayJay
Johnny
North Georgia
'20 JLR
I'm confused!
Jimmy, 68507574AA is listed as the diesel box on the TSA. 68507569?? is the four door non-diesel box. It appears that there has been a change in the revision suffix letters on the box, not a change in the basic part number.
Later,
Johnny
Tsalvador
Houston TX
Jeep Wrangler Rubicon 2021
Dud you remove the steering stabilizer and tested it yet?
I havenā€™t. Dealership insists itā€™s normal behavior. Jeep cares repeats the dealer. Iā€™m now about to start taking the matter on my own hands.
Likely with the steering stabilizer replacement and the mopar 2ā€ lift kit LCAā€™s - and see whatā€™s next
2mnycars
Canada
JLUR
Later,
Johnny
Thanks Johnny.
My summary. The steering gear was changed out by the second dealer I approached. It was done perfectly, according to the first TSB. Observation...driving is much better. Stays in lane; not scary with a side wind. No mess; wheel was centred. It DOES have a bit of a dead spot. About 2 inches. I don't know the cause, or the fix.
My question--to myself. Is it good enough? Frankly the improvement is real. I see so many people with real problems after their steering gear is swapped out. I've been freaked out by the second TSB. the replacement TSB.
LS7
Salt Lake City
'66 CJ5, ā€˜18 JLUR
Another steering story: My 2018 JLUR was delivered in May, 2018. I didnā€™t have what I considered to be extra play in the steering wheel, but I had to continually make steering corrections to keep the Jeep going straight. My dealer subsequently installed two updated steering dampers, which slightly reduced the wondering, but I still had to make steering adjustments to stay in my lane. Last year, I was getting bored with COVID confinement, so I decided to install a Mopar lift kit. I also installed Core4x4 front and rear, tier 4 track bars to center the axles, Method wheels and BFG 35ā€ KM3ā€™s. After these modifications, my steering improved, dramatically. I still had to occasionally make a steering adjustment, but my steering was 90 percent better. It should be noted that the lift did not change my caster. It remains at 6.4 degrees, where it was before the lift. Last October, I got on the list for a new steering gear, which was installed about a month ago. My Jeep now tracks perfectly. I can take my hands off the wheel and the jeep continues to go streight. Steering response is good, I still donā€™t have excessive play, and I have not noticed a change in steering effort with the new gear. I guess Iā€™m one of the lucky ones.
